Overhead Garage Door Lubrication In Dusty Barn
   / Overhead Garage Door Lubrication In Dusty Barn #1
KennK
NE Wisconsin
John Deere 3320
About every year or two I lubricate the overhead door in my garage using a white lithium grease spray.
I also have a newly built horse barn with two overhead doors, and the time has come to lubricate those doors, but I'm hesitant to use white lithium grease spray - especially on the big round springs - because a lot of dust settles on top of those springs.
Note, the dust comes from the horses. They roll on the ground, come inside the barn, shake, and create a cloud of dust that travels throughout the barn.
Can I get by using a dry lubricant spray instead? Assuming I brush off the dust first.
   / Overhead Garage Door Lubrication In Dusty Barn #2
Don't agonize over it. I've seen springs on 30 year old garage doors that were never lubricated. Blow off the dirt/dust and give them a quick shot of lube.
   / Overhead Garage Door Lubrication In Dusty Barn #3
Yea and I've had 2 fairly new ones fair in the last couple of years. That's why I like the roll up doors.
   / Overhead Garage Door Lubrication In Dusty Barn #4
what are you lubricating? hinges, rollers, pick up lever, etc? is it belt or chain driven? i use my bike chain dry lube, Triflow dry lube on mechanical parts in dust environment, locksmiths & cyclists love it too, regards
   / Overhead Garage Door Lubrication In Dusty Barn #8
I only use silicone spray on rollers, springs, hinges. Once about every 6 months.
   / Overhead Garage Door Lubrication In Dusty Barn #9
I leave dusty springs alone. If no additional lubricant is ever applied, dry dust is a pretty good lube all by itself.
NEW Fork Extensions (A53002)
NEW Fork...
2002 Kendall 12ft Enclosed T/A Trailer (A50324)
2002 Kendall 12ft...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
2002 Pierce Tilt Cab Hale Pumper Fire Truck (A50323)
2002 Pierce Tilt...
2022 Quick Attach Brush Buster - Heavy-Duty Skid Steer Cutter for Brush and Overgrowth (A52748)
2022 Quick Attach...
