Spreader Overhauled EZEE FLOW Spreader
   / Overhauled EZEE FLOW Spreader #1
farmforwildlife
South Carolina
A few months ago I asked a question about an EZEE Flow spreader I was going to overhaul. For those interested, this is how it turned out. A little weld, a little sheet metal, a rookie paint job, and a couple new tires. Field Ready!
   / Overhauled EZEE FLOW Spreader #2
Great looking rehab. What's the spreader's weight capacity?
Steve
   / Overhauled EZEE FLOW Spreader #4
Did you repaint the lettering by hand?
It looks really clear and sharp
   / Overhauled EZEE FLOW Spreader #5
Great Job. Sure Brings back a lot of good memories from my childhood. BTW, I found 3 in one location over the weekend.(2 EZ flows and 1 Deere) I don't know what the price is, however, I will find out this weekend. Ken Sweet
   / Overhauled EZEE FLOW Spreader #6
Wow, that looks too nice to use! Good job. Interesting to me because I just bought a similar spreader. I have not picked it up yet, but I think it is an Oliver, but it is very similar to yours. I will also restore mine (but may not paint it, as it has little rust) just make sure everything works and is lubed up. Several questions:
Does your have agitator disconnects on the hubs, and if so, are they complex?
Did you repalace any bearings?
What tires did you use and what costs?
What do you plan to spread and what will you pull it with? I was wondering if it will spread Ag lime or does it need to be pellitized.
I bought mine for $375, what is an average price? I never see any around here. Just wondered. Also, what advantages does this drop type have over the more common 3 pt. hitch cone spreader?
Thanks! Again that looks great!
   / Overhauled EZEE FLOW Spreader #7
nice job! :thumbsup: Have you gave it a test run yet?
   / Overhauled EZEE FLOW Spreader #8
Where are you in South Carolina? I am in Greenville and hunt in the upstate. I assume you will use this for food plots.
   / Overhauled EZEE FLOW Spreader #9
It puts seed or fertilizer exactly where you want it, and does it evenly
The "spinner" types throw different things different distances.
If you were to mix clover seed with fertilizer, the fertilizer would be flung farther than the seed
If your ground has been worked at all, it's easy to see the tire tracks so you know what's already been covered. It's harder to judge with a broadcast spreader
Being closer to the ground, you won't get wind drift on breezy days
You can plant right up to a fence line without wasting material on the far side
HCJTractor,
If it is like mine the agitator shaft will have a couple collars with set screws to adjust the float for alignment inside the spreader. The drive hub is a light press fit onto the agitator shaft with a woodruff key and drive pin to engage the wheel.
No Just a couple of bushings. No roller or ball bearing present just a lot of grease.
Nothing special. I actually lucked into getting them for next to nothing because a guy ordered them and never picked them up. However, you will also need a tube because your wheel probably isn't made to seal a bead like a tubeless tire does today.
I plan on trying to spread Ag Lime. They were used to spread Ag Lime in the past. I will also plant small grain seed/clover mixed in with the fertilizer.
$375 is a fair price if it is in good condition.
Also, in response to another post about the lettering. I made a template out of plexiglass and sprayed the black letters after painting the body.
2011 SHOP BUILT FLARE STACK (A53843)
2011 SHOP BUILT...
2019 Fecon BH74SS Hydraulic Mulcher High Flow Skid Steer Attachment (A51691)
2019 Fecon BH74SS...
Mohawk 12,000lb Two-Post Electric Auto Lift (A55851)
Mohawk 12,000lb...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A56138)
2015 FREIGHTLINER...
2005 Dodge Caravan Van (A54815)
2005 Dodge Caravan...
UNUSED 70PCS Black Metal Roof Panels (A53117)
UNUSED 70PCS Black...
