Outside or garaged!
/ Outside or garaged! #121
I like inside storage for resale value. I can tell the difference between my indoor-stored L-39 and one that's the same age left outside.
Hopefully my L-39 will sell for a bit more because it still looks new-ish.
/ Outside or garaged! #122
I keep my tractor and MMM in 'sheep shack" or pole barn. I keep the Agric roto tiller under a Doug Fir. I'm just now buying a roto mower.
Between the roto tiller and the mower I have about $2500 so I think I need another lean to or pole barn.
Anyone have any ideas on how to store an expensive rotary mower? I was just going to store it under another fir tree??
/ Outside or garaged! #123
I think most people, including farmers, just store their rotary mowers outside. You DO have to keep it well lubricated to prevent rust. I currently have a 10' rotary cutter that I keep outside and it cost quite a bit. It does bother me to do so. I've only had it for 6 weeks. I want to build a 3-sided slant roof shed to store my implements out of the elements. I could have them all lined up with one whole side open. That way I could just pull right up and hook up which ever one I wanted. Of course, the tractor would still stay in the barn.:D
/ Outside or garaged! #124
leeinmemphis said:
I'm building a 40x60 with a 15x60 lean to and will hopefully have all of my equipment under roof in the next 30 days.
This is my hope also, but with one difference. Mine will be in 30 YEARS. :D
/ Outside or garaged! #125
I built a 24 x 32 garage in 2005. Never did I think that my L3400 with Fel would fit in the back & wife's CRV in front with room to walk. So, along with my 3/4 ton pickup & snowplow, they are all in the heated garage. Minimum temp this winter in there was 35 deg.
/ Outside or garaged! #126
Inside!!!
My wife's car can endure the elements better than the tractor can. Besides it is easier to pull in the block heater when it is in the barn.
Rnady
/ Outside or garaged! #127
Good grief!!:eek: You really know how to make use of space! How tall is your garage door? I wish I would've put 12-foot doors in my garage. Unless I took my canopy off my ROPS I can't get mine in there if I wanted to. All the more reason to eventually build a new "tractor garage" with 12 foot doors.:D
/ Outside or garaged! #128
I think he hangs the L3400 on the wall. And hoists the CRV up on one of those bike pully things.
I have a 3-car about the same size that I keep a LR Freelander, an Expedition, the BX with implements, a work bench, and all government-required garage implements (generator, compressor, welder, shovels, rakes, jacks, refrigerator, duct-tape, zip-ties, safety goggles, bug spray, etc.) and can still walk around...quite nice. But an L? And the HD Pickup is a heck of a lot longer than my Expedition. Wow.
I am curious, though. If it is heated, I sure hope the minimum temp was 35 degrees. You must be trying to minimize energy costs and keep your spare water from freezing...
/ Outside or garaged! #129
Mine will be kept inside the heated shop right next to my other toy!
364cid NASCAR Modified, just over 600hp @ 8000rpm!
/ Outside or garaged! #131
B7800 in unheated garage with my wife's car and my truck-a little too tight so I am going to extend my small 3-sided pole barn that holds my firewood. I will run an underground electrical cable for the block heater and it should be fine
/ Outside or garaged! #132
Mild winters here help. Right now, BX is in unheated detached shop along with the convertable 'play car'. Car is rarely used and plugged into a trickle charger - battery is 7 years old and still fine. Implements (need more) under a lean to and tarped. Truck and suv in carport joined to the house. Problem is... will a planned L series fit in the shop with everything else?
There's a perfect spot for the BX in a single, walk out garage in the back of house with no driveway access....but gotta talk the wife out of her play/work room.
/ Outside or garaged! #134
Inside heated and air conditioned. Still looks like the day I bought it in '04
/ Outside or garaged! #135
Holy zombie-fied threads, Batman!
Tractor - unheated (but drywalled) garage
Implements - barn
/ Outside or garaged! #136
97 Ford Ranger outside.
00 Toyota Sienna outside.
05 Toyota Rav4 outside.
08 BX2660 and all implements, inside unheated garage. Never thought twice about it.
/ Outside or garaged! #137
All(both) of my tractors sleep inside.
Also I would like to confess that in 19 years of marriage once my wife made ME sleep outside.
Yes I came home at 5:47am with lipstick on my breath and whiskey on my collar! :laughing: :laughing: :laughing: :thumbsup:
Boone
/ Outside or garaged! #138
Since my truck is too long to fit in the garage, the 'bota, craftsman rider, push mower and ATV all live inside the garage. It is kinda heated. It has one small register.
/ Outside or garaged! #139
I can barely shoehorn my F150 into the garage with two garden tractors and my wife's car in there, but I do believe in keeping my vehicles in the garage.
So, had to get a shed for the 'bota. Unheated and no air conditioning for sure, but dry at least.
/ Outside or garaged! #140
Currently, 1 outside, 1 inside.
JOHN DEERE 2040 TRACTOR (A63291)
JOHN DEERE 2040...
2023 Kubota M7-174P (Premium) 4WD Tractor - 400 Hours (A63688)
2023 Kubota...
2018 FORD F450 XL 4x4 CREWCAB 5K LB SERVICE CRANE (A62613)
2018 FORD F450 XL...
17in. Tooth Excavator Bucket (A64194)
17in. Tooth...
2015 Nisan Altima S Sedan (A61574)
2015 Nisan Altima...
more info coming soon (A61569)
more info coming...
