Ordering a new lawn mower battery
/ Ordering a new lawn mower battery #1
Jerome Chrisman
Williston,ND
08 Cub Cade Volunteer 4x4 UTV
I have a 23hp John Deere lawn tractor with a Kohler motor.
The battery became dead suddently yesterday, I went to my local tractor shop to order a lawn mower battery,they quoted me $60.
Lawn mower batteries should be not expensive,then I do web search for competitor price only $20 to $35 on Amazon, Ebay is probably cheaper,even I find a kohler starter from Hexautoparts no more than $40.
Have you ever ordered a new battery ? If so,what's the reasonable price of a new lawn mower battery ?
I am not sure buying online is a good thing as I don't wanna waste time in returning.
Thank you.
/ Ordering a new lawn mower battery #2
I have never ordered a new battery on line. I don't have the time to wait for delivery and then the situation - what if its the wrong type or size. I have no idea where you are located but around here I would and have purchased a replacement battery for my JD G100 riding lawn mower from Les Schwab tires. It was either $42 or $45.
Indicating your location will go a long way to receiving a beneficial response in this case.
/ Ordering a new lawn mower battery #3
I don't know how things work in other areas, but in my neck of the woods, you have to pay a core charge (deposit) if you buy a battery and do not turn in your old battery. I don't have a clue as to how this works when ordering online.
I would check with local battery shops, auto parts stores, TSC, etc.
Steve
/ Ordering a new lawn mower battery #4
Locally, TSC has the best price on small batteries. I've had good luck with the lower priced (shorter warranty) ones by being very careful not to let them get discharged.
/ Ordering a new lawn mower battery #5
I get my riding lawn mower battery from Wally World at $21.87. They last about 4 years.
/ Ordering a new lawn mower battery #6
Just about any box store offer battery and some even give $'s if you return the old one.
I never order battery etc. online mostly because wait time and chance they might ship the wrong one.
/ Ordering a new lawn mower battery #7
you did not mention the CCA of the battery or the age, or any maintenance performed.
Batteries do die of old age or neglect, heat etc.
There is a code on the battery for size along with the CCA.
Maybe consider upgrading from a 150CCA to a 200 CCA battery for example.
Once decision on size and CCA is decided then wally wurl, TSC, NAPA you should be able to find your battery at reasonable price.
Regards
/ Ordering a new lawn mower battery #8
Thank you.
Don't make the mistake of buying based upon price.
A 23 HP Kohler needs lots of CCA to reliably start the engine.
From Kohler:
minimum current rating of 230 cold cranking amps hours should
be sufficient for cranking most electric start engine
models. Actual cold cranking requirement depends on
engine size, application, and starting temperatures.
Cranking requirements increase as temperatures
decrease and battery capacity shrinks. Refer to
equipment's operating instructions for specific battery
requirements
This is a minimum number. a higher number like 350 + will be more reliable for longer ntime.
Put a lower CCA battery in it thinking you save $ and you will waste time boosting it when hot.
If you want a low priced battery, make a frame for a standard car type battery on the front of your tractor.
A tired car battery will do a great job on a garden tractor.
Dave M7040
/ Ordering a new lawn mower battery #9
The battery rule is to buy the best battery you can afford. Cheap batteries are just that. I put in 300 CCA maintenance free Exides. Deka batteries are very good as well as Interstate. Remember that batteries lose strength as time passes. Low output is hard on the starter motor as well. You also need to be careful on aftermarket starters on Kohler for what it is worth.
/ Ordering a new lawn mower battery #10
It seems all batteries have substantially increase in price in the last 2-3 years. Standard lawn and garden tractor batteries used to be about $20-25 anywhere you looked. NOW they can run $50 or more for the same battery. Last time I bought one spring of 2018, there was a $10 core charge. I came across a stack of the at Atwoods Farm and Ranch store for IIRC about $25 so I snatched one up. Most batteries that fit in the battery box on lawnmowers are going to be 230CCA.
/ Ordering a new lawn mower battery #11
The Everstart batteries at Wal Mart are made by Johnson Controls while many of the auto part store brands are imported and not very good.
/ Ordering a new lawn mower battery #12
It is true that the Walmart batteries are made by Johnson Controls.
What we do not know is if Walmart dictates the (price/cost) specs. for their brand of Johnson built batteries.
That said: I buy only Walmart batteries. They seem to be the most cost effective.
I have found the only difference being that other brands are very often more expensive, and never seem to last any longer!
I use battery maintainers on all of my batteries.
To be honest,I had a unhappy online shopping experience before.Waited for two weeks but receive nothing.I was a little hesitant this time.I live in ND and went to another one battery shop yesterday,the cheapest I found here is $55.Seems a little more expensive than WA.
Wow,that 's a great deal.And you buy another and get four years, and another and get four years totaling 12 years for $60.00.And the cheapest one I found in my city,Williston,NC,is about $55.And I am not sure how long it will last.
I don't know much about the influence of high CCA vs lower CCA before.
You made it clear to me.
Dave M7040,thank you for your sharing and great suggestion.
From Kohler:
requirements
Dave M7040
/ Ordering a new lawn mower battery #16
A couple of things.
1. Batteries have increased drastically in price in the last year. A previous 25 dollar battery now is in the neighborhood of $50.00.
2. Measure the old battery that came in a John Deere. Also measure the battery compartment or location on the unit the battery sits. To find a replacement battery the same size as the original or will fit into the battery compartment area just about forces one to purchase the replacement battery from John Deere.
/ Ordering a new lawn mower battery #17
A couple of things.
Really, batteries have doubled in price in the last year?! I haven't experienced that in my neck of the woods.
/ Ordering a new lawn mower battery #18
Just bought a new battery off ebay for my motorcycle. It had a Battery Source battery in it. They wanted $75 + core + tax + disposal for a replacement. Harley wants over $100 for one. The sealed AGM Pirate brand battery I bought was $42.75 to my door in 2 days. Read reviews on it on Amazon and it had 4 stars out of 99 reviews. Several one star reviews so I hope it pays off and works okay for me. Started the bike as soon as I installed and it started but it's been raining ever since so no riding yet.
/ Ordering a new lawn mower battery #19
No significant battery price increase here either.
