Ordered my work lights- what about a tooth bar?
/ Ordered my work lights- what about a tooth bar? #1
pjwbx2230
Coshocton, OH
kubota bx2230
Based upon the knowledgeable advice of those on this board, I just ordered worklights for my new bx2230. Now, what are the benefits of a toothbar for the FEL? How difficult is it to install one? What can I expect to spend? Can it remove stumps? It will help with minor excavating, right? Just need a little advice. Thanks and Merry Christmas and Happy Holidays.
PJW
/ Ordered my work lights- what about a tooth bar? #2
I have a toothbar for the loader on my BX1500. It was lumped together with everything else when I purchased my tractor but I think it cost me somewhere in the neighborhood of $275.00. I have only used it for a couple of hours but it does help dig in hard soil and makes it a little easier to pull up stumps because you can hook the teeth underneath the roots and pop them loose. Of course it depends on the size of the stump you are trying to pull up. As others have said it also makes it a little easier to handle brush because the teeth act like little forks for lifting things.
/ Ordered my work lights- what about a tooth bar? #3
I forgot to mention the install part. I think most toothbars are like mine in that they slide over the edge of the bucket and attach to the bucket with a large bolt and nut on each side. It will require that holes be drilled or cut with a torch on the sides of the bucket.
/ Ordered my work lights- what about a tooth bar? #4
I used a cordless drill to install mine on a BX22.
/ Ordered my work lights- what about a tooth bar? #5
I bought what they call a landscapers tooth bar it works awesome check out my site to see it
Went with two Kubota lights to mount on each side of the ROPS. AMR set me onto the set up in another thread I started (New to forum- need some help). Lots of good ideas and a link to a lengthy thread about ROPS lights. Anyway , this is AMR's response and, hopefully, a link to his photo:
This is a photo of the Kubota lights, the dealer installed them for me for $120 (furnished and installed). They rotate front or back with a wrench. So far I love them. I mow, plow, and fertilize at night, not because I want to but that is when I get the time! You can see they are attached with a simple bracket. http://www.tractorbynet.com/photos/data/529/18797lights-med.JPG
/ Ordered my work lights- what about a tooth bar? #8
I ordered my toothbar from markham, for my 72" bucket, it was around 280.00.... haven't recieved it yet but I think the install will be simple....
/ Ordered my work lights- what about a tooth bar? #9
</font><font color="blue" class="small">( I ordered my toothbar from markham, for my 72" bucket, it was around 280.00.... haven't recieved it yet but I think the install will be simple.... )</font>
On my B7510 with 4' bucket I had to drill a 1/2" hole in each side of the bucket. It takes me about 5 minutes or less to install or remove.
Money well spent if you do any digging and very handy for cleaning up brush.
Bill Tolle
/ Ordered my work lights- what about a tooth bar? #10
I have a Kubota 3410 with 72" FEL. I put the tooth bar on myself - had to drill two holes as I recall. Not a major problem. I would not be without the toothbar. If someone took it, I would order another immediately and be unhappy until it arrived. It makes many jobs easier and makes the FEL so much more versitile. For my range of uses, I simply leave it on.
/ Ordered my work lights- what about a tooth bar? #11
I'll be installing the toothbar for my B7510HST/LA302 FEL today. It's from Markham Welding ($173 + $50 UPS). Was delivered last Wednesday.
Don't expect any problems since you just drill two 1/2" dia holes in the sides of the bucket for the bolts. I'll use a Milwaukee bi-metal hole saw to drill the holes since the bucket side metal is pretty thin. Markham includes two 3/8" stiffener plates about 3"x3" that you can weld around the hole for reinforcement.
The toothbar slips over the digging edge of the bucket and is designed for buckets that have the digging edge welded, not bolted, to the bucket. Contact Markham if you have the bolted type.
Markham Welding
(1) 74"X49" TAILGATE (A64280)
(1) 74"X49"...
PALLET OF MISC METAL (A63291)
PALLET OF MISC...
1998 Freightliner MT45 Step Van Food Truck (A61573)
1998 Freightliner...
1999 Sea Ray Boat w/ 2015 Shorelander T/A Boat Trailer (A61574)
1999 Sea Ray Boat...
2017 Ford F-250 Ext. Cab Pickup Truck (A61573)
2017 Ford F-250...
2019 Chevrolet Tahoe SUV (A61574)
2019 Chevrolet...
