Ordered an M5-091 cab / no loader
   / Ordered an M5-091 cab / no loader #1
KenBike
Wakeman, oh
Kubota M7040
Decide to go with a new M5-091 for mowing my horse pastures. snow blowing, hay making.
Keeping my L6060 for loader work, roto tilling ect. Looked over red, green, and blue tractors but liked the orange the best and getting a good deal. Added air ride seat, 3 remotes, Goodyear radials, buddy seat, radio, defogger, wiper, and three point remote from the rear of the tractor.
Should be ready to pick up in 4 weeks. Saved 11K going with the 091 vs 111.
   / Ordered an M5-091 cab / no loader #2
111 and 091 same physical size too. Wondered the real world price difference.
Should be nice when it comes.
Picked up the tractor Wednesday and drove it 12 miles home.
It maxed out at 18.9mph vs 23.9 as shown in specs. Turns out when it is ordered with the tallest tire size you have to go into the display and enter the size of the tire in inches. Disappointed the factory or the dealer did not take care on their end.
Came down with a ass kicking cold/flu so have not yet put it to work.
So far so good.
   / Ordered an M5-091 cab / no loader #4
So far so good.
Too bad they didn't take care of the speed coefficient. Seems like normal set up to me.
Called my salesman he said service should have set it up. Only took a few minutes but it was a slow ride home.
Rear tires had 25 psi dropped to 21 psi, more squat so should soften the ride. Going to mow this week and see how it does pulling the batwing.
   / Ordered an M5-091 cab / no loader #6
Congrats on the new ride.
Mowed the back 10 Ac field today and it was a easy cruise. Set it on E-PTO and 6th gear low and had no issues. The tractor rides so much smoother than the L6060 or my M7060!
Love how quite the cab is and great visibility.
   / Ordered an M5-091 cab / no loader #8
I'm sure the speed was the same, you just thought you were going slower. I think the coefficient adjustment is just so the display shows the correct speed. unless these fancy new tractors have some kind of speed limiter either way larger tires would have meant you were actually going faster than the display indicated so you wouldn't have hit the limiter you would have maxed the revs on the engine before hitting the electronic speed limiter.
Congrats on the new tractor. How does it compare to the 7060, must be a little heavier and perhaps a longer wheelbase. unless it is the tire size that makes the ride smoother.
Was interesting the RPM's are the same before the speed limiter setting, just seemed faster with the speedometer reading 24.3 vs 18.9!
Compared the the open station M7060 it is a lot larger when you are in the cab. The tractor is tall with the tire set I wanted and the wheelbase is slightly longer. The M5 has the rubber mounted cab and it provides a softer ride for sure. When crossing rough stuff the gear shift lever moves around due to being mounted to the transmission and not part of the cab isolation system so you can see how much smoother the cab rides.
Also surprised how quite the cab was, when mowing really did not need to use ear plugs.
I have two issues with the new tractor.
1. The AC switch is not powered by the key off so when I shut down if forget to turn off fan for AC/heat will have a dead battery. My L6060 cab was powered only with key on.
2. Getting a very rough vibration/shaking at times, more noticeable when pulling a load. Coming from rear of tractor and it will last for a few seconds. I am suspicious may be a issue with the rear differential lock sticking or the tractor on it own tries to lock rear diff. Note the cab is mounted on rubber isolators and the gear shift lever is coming from transmission. Even the gear shift lever vibrates or shakes for a few seconds usually when corning.
Waiting to get it back to the dealer to check out.
2016 Dodge Journey SUV (A53424)
2016 Dodge Journey...
2008 Ford F-550 Flatbed Truck (A52377)
2008 Ford F-550...
2016 Big Tex 14LX 14ft 7 Ton T/A Dump Trailer (A50322)
2016 Big Tex 14LX...
UNUSED Tool Set (A53117)
UNUSED Tool Set...
2016 Ford Explorer AWD SUV (A53424)
2016 Ford Explorer...
2022 MACK GRANITE TANDEM AXLE DUMP TRUCK (A54607)
2022 MACK GRANITE...
