Ordered 2305
/ Ordered 2305 #1
Fatboytrike
Hey everyone, have been visiting for quit a while, finally registered....Thanks to all the info on this great site I have ordered a new 2305...200 CX...48" box blade....54" front blade with quick hitch...ballist box and I-match..
I still want to get a post hole digger...I know about the limited class 1. But would like to find out what makes of post hole diggers 2305 owners are using. And also what length augers you are able to use...28" 30" 32" longer?
Tractor should be here in about a week...:)
/ Ordered 2305 #2
Congrats! :D You should enjoy the new tractor.
I have a PHD for my JD2305.
http://www.tractorbynet.com/forums/jd-owning-operating/100848-jd2305-phd-questions.html
Even though the PHD is made for the SCUT's I still need to cut a few inches off the drive shaft. I will post how that works out this weekend.
When using the box blade remember to engage 4WD or else you smoothing out your back tire holes.:rolleyes:
/ Ordered 2305
Thanks for the info cdhd2001... I,ll look forward to seeing how that works out for you.......Will watch for your post
/ Ordered 2305 #4
Hey cdhd2001,
What brand of post hole digger is that? Just curious...
/ Ordered 2305 #5
aesanders said:
Hey cdhd2001,
Ag Meier PHD. Local Cub Cadet sells them for their 5234 (same size as my JD2305). The complete PHD including 9" auger was $535. My local TSC sells PHD's for about $50 cheaper, but doesn't carry one compatible with the Limited Cat 1.:rolleyes:
/ Ordered 2305 #6
I cut 8 inches off the PHD drive shaft and completely cured my woes!:D
(APPROX. 34) 2X6X10.5 ROUGH SAWN OAK (A64276)
(APPROX. 34)...
2015 John Deere 8295R (A64119)
2015 John Deere...
2025 Hydraulic IRANCH Tilt Bucket Mini Excavator Attachment (A61572)
2025 Hydraulic...
2014 Freightliner M2 112 Tandem Dump (A62613)
2014 Freightliner...
2022 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Mack Anthem...
APPROX (12) REGENCY STAIR KITS (A64281)
APPROX (12)...
