Orangeburg Sewer Pipe problem
   / Orangeburg Sewer Pipe problem #21
I just discovered this thread late, glad to hear it's all taken care of.
I just can't believe they used the orangeburg for sanitary sewer, never seen that before. I have seen it for septic system leech fields, but every piece of orangeburg pipe I've ever encountered underground was deformed, some in as little as 20 years. Mostly used around here for residential storm water management, I have seen it under basement floors for perforated footing drains and it seems to hold up in that application fine.
I've never seen anything other than 4" orangeberg, perforated and solid. Supposedly they made it from 2" to 18"
Just googled it to learn a little more, Bituminized fiber pipe, made from wood fiber and coal-tar pitch, which would explain it's poor structural integrity. I see it was used for sewer laterals in many locations, but as far as I now not around here, and I know alot of contractors that do sewer work.
We went from clay to plastic, still alot of clay sewers around here, replaced when necessary, but they hold up well, some close to 100 years old and 36" in diameter.
JB
JB
Home was built in 1956 back when Orangeburg was popular here in my California City...
In general, it was only to be used for laterals when used for Sanitary Sewers. The builder must have really liked it because it continued under my attached two-car garage and I didn't want to dig up a perfectly good concrete floor and I also didn't want to do only a partial replacement.
I've come across Clay, ABS, HDPE, Cement Asbestos, Orangeburg, Cast Iron, Copper, Galvanized and even Redwood pipe in Santa Cruz once...
The new regs are going to keep the sewer guys very busy for years... can't sell a home without a Sewer Inspection and clean bill of health... the only lines that have a chance on passing are ABS, HDPE and sometimes Cast Iron... although rarely.
What they do is block the line and pressurize it and watch for leak-down... pressure testing is something older lines were never designed for.
The one copper line was in an old estate... the sewer guys joked and said whenever they find copper they fail it, remove and replace with plastic and stop at the scrap metal yard on the way home...
It's kind of ironic because the oldest and most deteriorated sewer lines are owned by the city...
I did learn a few things...
The HDPE will stretch as it is being pulled into place... the plumber said it can shrink several inches on a long run after it cools and the pipe "Memory" kicks in. They actually beat on the end of the pipe to help with shrinkage.
A few things I learned.
The pipe run doesn't have to be 100% straight... small variations and bends are OK.
About 18" minimum below grade to the center line of the run is required on the end with the pulling head...
I was all set to back fill the trench at the main and learned that I needed to wait till the rain water subsided... otherwise the weight of the back fill material would cause the line to sag in the wet soft earth.
The rubber couplings they use are 4 band, 80 psi rated... the HDPE is 100 psi rated with heat welded joints.
The Pipe comes in 20 and 40' lengths...
The rig runs between 30 and 40k for 4" line replacement.
The bursting head can go through just about anything except pipe encased in concrete...
Up-sizing generally isn't a problem... especially from 4 to 6 inches...
Code now requires the pipe to be light gray in color instead of black... the reason is much better contrast when taking pictures inside the line with the light gray color.
   / Orangeburg Sewer Pipe problem #24
I didn't read all the posts in this thread.
About 20 years ago a friend living in Santa Cruz California solved a neighbor hood problem, the sanitary line failed for several houses near the lighthouse. He, a retired plumber, found in the city records the path of the line. He said that knowing the year it was installed it would be for sure Orangeburg. The line was dug up, it was Orangeburg, it was replaced. This was Nick Rich retired plumber living still ,I pray, in the Octogon near the lighthouse.
   / Orangeburg Sewer Pipe problem #25
Wow, so if the pressure test fails the house sewer has to be repaired/replaced :confused2:
That would be every house around here more than 45 years old with clay house sewers to the street.
Are those new regs based on environmental concerns?? or excess ground water infiltration into the sewer system/ treatment plant.
The ground water infiltration has been the issue around here, and they have been relining the sanitary sewers in the street, but no burden on the private property owners to make any repairs.
Around here the sewer pipe in the house was 4 inch, cast iron. Now pvc or abs. plastic, as soon as it exits the house it has to be 6 inch pvc minimum
JB
   / Orangeburg Sewer Pipe problem #26
The mandates to test and fix sewer lines is from sound evidence that sewer leakage, leeching of sewage into water tables causes great harm. Medicines can be found in urine, now that leeches into your drinking water, or the water your kids will drink. Bad it is. The test is usually 10' of head of water on a line creating 5 lbs pressure (approx) or 5 lbs pressure or air. An inspector will usually let you get by w/ just filling the sewer less a head of water.
The mark ups the plumbers are making are not excessive at all. That 50K worth of machinery has to be paid for and maintained. The pipe used has royalities that must be paid as well. Employees must be paid well or they start their own business's. 1 Million liability insurance, workmens comp, fuel ins on and on and on . The plumber protects the health and welfare of the nation. The wannabe, know-it-all, pretend plumbers, destroy it...usually unknowingly.
I am very glad to see you fixed it right, I might need to drink that water some day or the food I eat might be watered from a water table now protected.
   / Orangeburg Sewer Pipe problem #27
Pharmaceuticals are found in surface bodies of water down stream from sewage treatment plants. Yes this is a problem we are just now learning about, but those elevated levels are due to the fact that all the waste water from the entire geographic area serviced by that plant is concentrated at the plant. The drugs are not broken down with normal sewage treatment techniques, and are then being discharged into the tributaries with the treated water.
The trace amounts that might be lost on the way thru the sewer line would be minuscule at most and almost certainly not be a threat to drinking water supplies, without a very vivid imagination.
Sewage leaking from pipes should have little adverse effects on drinking water supplies as well, since most municipalities that have sewer service would have city water. and considering the fact that areas that don't have city sewer or water would have septic systems and drinking water wells on the same lot with historicaly, little ill effects.
JB
   / Orangeburg Sewer Pipe problem #28
Well I guess I have a very vivid imagination, as do the powers that be that are demanding an almost no tolerance in sewage water getting into drinking water. Leech fields and Ceptic tanks and the like have only been around for what, 80 years or so, maybe a little better? Let's call it 100, OK? That is NOT enough time for X to seep into Y in Many areas. In a nutshell your saying a little bit of sewage in your cup O tea is OK. I can't get behind that thinking, ever.
   / Orangeburg Sewer Pipe problem #29
I'm saying you most likely wont get sewage in your tea, but I surely don't know the situation in all geographic areas.
The fact that septic systems have been around that long around here with no evidence of contaminated drinking water is my evidence, for this area anyway. and why I believe the little waste water that is lost thru a sewer line that wont hold pressure is a non issue IMO.
JB
   / Orangeburg Sewer Pipe problem #30
JB
The differences due to location couldn't be more at opposite ends of the spectrum.
Like I mentioned in post #25 we are spending countless millions of dollars to prevent filtered, clean ground water from getting into our municipal sewer system. There is an environmental benefit to that, as to much storm water at the plant prevents proper treatment and often overwhelms the plant during heavy rain events.
Regarding the pressure test for your sewers, consider this, in an average sewer pipe that was installed properly the flow is on the bottom 1/4 of the pipe, (on a 6 inch house sewer it is actually much less) so the only part of the pipe that could leak into the soil is that small percentage at the bottom.
But you are subjecting the whole pipe to the test obviously, so 75% of the pipe that is out of the flow, could be blowing the test but could have no effect on it leaching out.
Plus any slight defects in the part of the pipe where the flow is, that could cause a leak, would be filled with scum anyway.
So yeah great mandate for the sewer contractors, bad for the property owners and very tiny, I would say near zero benefit to the environment.
JB
2016 PETERBILT PB337 FLATBED TRUCK (A52706)
2016 PETERBILT...
Mohawk 12,000lb Two-Post Electric Auto Lift (A55851)
Mohawk 12,000lb...
HUSQVARNA RIDING MOWER 42IN DECK (A56859)
HUSQVARNA RIDING...
2025 Swict 78in Bucket Skid Steer Attachment (A56857)
2025 Swict 78in...
2011 Isuzu NPR 14FT Box Truck (A56858)
2011 Isuzu NPR...
2022 Brush Wolf 4800X Severe - Duty Excavator / Backhoe Brush Cutter (A57024)
2022 Brush Wolf...
