Options to get with HD rear blade
   / Options to get with HD rear blade #11
Hydraulic angle would sure be nice.
I just added rear remotes to my 2320 and the next project is to modify my rear blade some more to accept a cylinder for angling while still being able to roatate it 180' deg if so desired.
I could see offset angle for work near ditches as a safety bonus but a larger tractor would probably be needed for sure.
   / Options to get with HD rear blade #12
Piston, it was not me that had found the used blade, but Zebrafive. I had only quoted him and that is why it looks like I had posted what you have now quoted.
I have a Land Pride RBT45108 for my 7520 :thumbsup: :thumbsup: and am hoping to get an RBT3584 later this year for my 3215. :drool:
wow thats confusing :laughing: Even looking back at post #6 I still don't really get it, but that's okay, I don't get a lot of things :laughing:
I'm on the lookout for a used RBT4096 with 3 way hydraulics, I think it should be my next "victim" :D
   / Options to get with HD rear blade #13
IMO - It's mandatory for a blade to be fitted with hydraulic angle, tilt & offset with rear wheels for serious work- though @ 3m/9'10" & CatII/III linkage a 70hp or better tractor is required :-
I know this is a semi old thread, but did you end up buying the 121-09?
I did buy the Bush Hog 121-09. It only came with an angle cylinder I have since added an offset cylinder. I may add a tilt cylinder. I do have hyd top link, but not side (tilt) link.
   / Options to get with HD rear blade #15
How do you like the blade? Have you used it much? What do you use it mostly for?
That seems like a very heavy duty and well built blade.
   / Options to get with HD rear blade #16
I have the RBT3584. I was stretching my budget and only have 2 remotes, so I got hyd on angle and tilt, but manual on offset. For anyone who is considering options on a rear blade, I have to say my choice was a mistake based on my requirements which include snow and dirt -- if only getting two, I would get angle and offset, and do the tilt manually.
   / Options to get with HD rear blade #17
Those are some nice hydraulic control rear blades. If I was using one every day like in a dairy or feed lot operation, pulling side ditches, bedding new drives with a heavy tractor that would be fine. For my personal usage I would just get a heavy duty manual so it would cost less and be strong enough for our needs since it would have to be parked outside.
2000 Trinity Built Trailer (A50514)
2000 Trinity Built...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A50323)
2009 Peterbilt 384...
2020 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A51242)
2020 CATERPILLAR...
2012 Ford F-150 Crew Cab Pickup Truck (A50323)
2012 Ford F-150...
2005 Ford F-550 Bucket Truck, VIN # 1FDAF56P45EB88239 (A48836)
2005 Ford F-550...
Land Honor Quick Attach Land Plane (A50514)
Land Honor Quick...
