Mowing opinions on a good 10' rotary cutter for our 5250
   / opinions on a good 10' rotary cutter for our 5250 #1
labsrus
We are looking for a new 10' rotary cutter for our JD 5220. Can we have some opinions on really good ones?
Thanks for any help.
We have a Howse right now but it just does not hold up to good.
   / opinions on a good 10' rotary cutter for our 5250 #2
I have a LandPride 8ft HD and a Woods 12ft HD both these are good cutters.
The only thing I like better about my Woods is the flat deck(just easier to clean).
Have pics if u like to see them!!
   / opinions on a good 10' rotary cutter for our 5250 #3
what model of howse do you have?
I have the HD 10' model and it's a beast. had it for 7ys now.. deck metal is even thicker than my JD batwing.
I've knocked down 4" trees before with it on a wide swing. For years it ran behind a 95hp tractor before I moved it to a 70hp tractor.
I've yet to damage it enough to even scratch all the way thru the paint on the deck.
soundguy
   / opinions on a good 10' rotary cutter for our 5250 #4
I like the look of the Rhino Turbo series. I'm thinking of getting one in 8', semi-mounted. Possiblely with the hydraulic offset option.
   / opinions on a good 10' rotary cutter for our 5250 #5
This one in a 10ft(12ft shown) 5040 and ds rear view.JPG or this one(8ft shown)tractor3.JPG
This was my old howse (10ft shown)I used the crap out of(never replaced anything but blades 6yrs)but I dont think the new ones are made the same!shredder 3.jpg
   / opinions on a good 10' rotary cutter for our 5250 #6
I second the Woods brand I have a DS96 (the 8' pull type version). One thing to keep in mind is these mowers run a good bit wider than the cut width. For example the DS96 (96" cut is actually around 104" wide over all). Just something to consider if you have width restrictions.
   / opinions on a good 10' rotary cutter for our 5250 #7
I have a Rhino SE 10 Semi Mount , it cuts good and is built well , Blades are very are easy to service , Just keep them sharp ! All around I'm happy with it
   / opinions on a good 10' rotary cutter for our 5250 #8
I have a 10' Williams/Hardee/Tiger pull-type cutter. (no longer made) Built like a tank. Weighs about 3000 pounds. It's close to 20 years old and the only repairs have been a broken input shaft on one of the side gearboxes, and a couple of pillow block bearings for the PTO shaft. The broken shaft was the result of hitting a hardwood stump while the cutter was beeing pulled by a 100 hp tractor. The busted bearings were the result of trying to cross a creek channel while the PTO shaft was still turning. (just ran out of travel) So, other than operator stupidity, (mine) there have been zero breakdowns.
I also have a Rhino SE7 7' single spindle cutter that is 3-pt hitch. It's considered a medium duty machine. Overall, it's been good, but I've bent the side skirt in a couple of places and I had to replace the tail-wheel because it kept bending. (and it's only about 5 years old) I wish that I had spent a few hundred more for a heavy duty cutter.
I said all that to say this: Nobody I know of has ever regretted buying a cutter that was TOO HEAVY DUTY! ;)
If you are tearing up the cutter you have now, I would suggest that you don't buy an "economy" model, or even the "medium duty" of any brand. Go ahead and pony up for a heavy duty or even a commercial duty cutter.
   / opinions on a good 10' rotary cutter for our 5250 #9
ditto that. I don't regret paying more to get the 'hd' model of the cutter I have.
soundguy
3/8 '' Wolverine Universal Quick Attach Cut Out Mount Plate (A51573)
3/8 '' Wolverine...
1990 Ingersoll Rand 185 Towable Diesel Air Compressor (A52377)
1990 Ingersoll...
FRONTIER MG20F LOT NUMBER 82 (A53084)
FRONTIER MG20F LOT...
BOBCAT T595 LOT NUMBER 153 (A53084)
BOBCAT T595 LOT...
Echo SRM2620 Gas Trimmer (A52377)
Echo SRM2620 Gas...
2001 HEIL PNEUMATIC CEMENT TRAILER (A52576)
2001 HEIL...
