Opinion needed on New Compact Tractors.
   / Opinion needed on New Compact Tractors. #61
Also the Branson one lets you put the PTO in neutral. Then the PTO stub on the tractor will turn easily by hand, so you can line the splines up with the shaft you're attaching. Otherwise the PTO brake keeps it from turning. I have no idea if they did this on purpose and it wasn't something I knew when I bought it, but it's handy when hooking up a PTO chipper with a 220lb flywheel.
I see many of you guys struggling with that situation.
Did you ever try to shut down the engine and then hooking up the implement? In some cases, the PTO brake is activated by hydraulic pressure. With the engine not running, you can turn the stub by hand.
Ask me how I learned that.
   / Opinion needed on New Compact Tractors. #62
Not on most compact tractors though. The PTO brake is usually spring applied.
If there is no way to put the PTO in Neutral, it's a pain to hook the PTO shaft.
2022 FREIGHTLINER CASCADIA SLEEPER (A56129)
2022 FREIGHTLINER...
Hydraulic Liftgate (A59230)
Hydraulic Liftgate...
2013 Haulotte 4527A (A57148)
2013 Haulotte...
UNUSED IRANCH IRTPL 10000Ib TWO-POST CARLIFT (A60432)
UNUSED IRANCH...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A58214)
2014 FORREST RIVER...
