OPERATIONAL TIPS FOR NEWBIES
/ OPERATIONAL TIPS FOR NEWBIES #101
although a 136h newbie myself... +100 for tugboat!
you tow a trailer, a caravan or a speedboat
all these being happy things, fun and with the target of moving something to a better place
you pull a root, a house down or a tooth
all these being brutal, dangerous and eventually painfull when using the wrong tools and potentially risking to move something else to a final place.
pliers, tweezers and winches being dedicated tools for pulling dedicated things
with cars, trucks and tractors being dedicated tools for towing equipped with towing points.
In my near area i have a grandfather who drove over his grandchild with his Zetor, a dead farmer with a 20ft thrown off head by a manure spreader while his kid was handing him wrench nr 19, a 1 arm pto-hugger and a farmer family mourning as their youngest fell in the stable septic while father was spraying on the land.
Statistics are best when you are not part of them. Dont take chances, they are in limited supply.
/ OPERATIONAL TIPS FOR NEWBIES #102
Right-On, tatra805! ....and welcome in. Nice to hear from a fellow-tractor-man from way, way, across the sea,... so far off geographically,..yet so very close internetally!
. . tug
/ OPERATIONAL TIPS FOR NEWBIES #105
Hee, Hee, Hee !!! Avatar/comment,...yes a winner!!
DUDE !.....Good One !!! definitely got a giggle outta me!! Hee, Hee!
CHEERS !
. . tug
/ OPERATIONAL TIPS FOR NEWBIES #106
Simple rule:
If tractors were meant to have people ride along there would be more than one seat.
/ OPERATIONAL TIPS FOR NEWBIES #108
I appreciate the responses to my question. Looking at it again, I think my thought did not quite come through the question I asked. Guess I should've prefaced my post with: "Following all aforementioned great advice like any intelligent tractor operator should, obeying all safety rules and limitations of the equipment in question, said equipment being properly connected, loaded and secured, and tractor operator being fully conscious, sober and alert" and then asked: Any opinion on whether the aforementioned 3-pt. hitch adapter, (steel triangle that connects to all 3 points of the 3-pt hitch and accepts a standard pick-up 2"x 2" hitch-ball mount) with said 3-pt hitch in a properly lowered position, would be any better or worse than towing with the drawbar in which a standard hitch ball does not fit properly without some sort of bushing or adaptation?
I might be a newbie, but I can use lots of words (some big ones too) in one sentence :D.
'Dude's avatar/advice: :D:D:D
LBrown: Ouch, man. Sad story. Point well taken. Carelessness, impatience, inattention, fatigue all can be stealthy enemies, wreaking havoc or worse when we least expect it.
/ OPERATIONAL TIPS FOR NEWBIES #109
Colby,.....(by the way I'm trying to "read-ONLY" for a while),..so I'd say taking into account "all" your stated facts to wit: load, safety et-al,....you have just answered your own well worded question. . . ...........somebody else?
Good Luck to you,
. . tug
With all these great post 1 thing keeps showing up, know when to say when. I had a job that was paying really well and close to home with my b3030, it raind real hard overnight and the guy was pissed i would not work the slope that day. He called me the next day and wanted to know if I could help him pull his truck back p the slope I was grading and filling. He didnt realize how slick and dangerous fresh dirt mixed with claw was when it was wet.
and a side note:
dont use a FEL or BH to apply extra pressure to a rock bar, you will bend the bar not move the object. lol :rolleyes:
/ OPERATIONAL TIPS FOR NEWBIES #111
Just go get the bushing, it is cheap.
The factory engineers have put a lot of effort into assuring that the tractor will not overturn if you pull from the drawbar.
If you pull from the 3 point hitch the tractor can overturn. Also, since there is no downpressure on the 3 point, it will automatically lift up as a hard pull tries to overturn the tractor, making the situation worse.
If you have your seatbelt and ROPS you may survive.
Your adds are a lot better using the proper drawbar.
/ OPERATIONAL TIPS FOR NEWBIES #112
If I had any pull on the 3pt drawbar.. I'd be using stays for sure!
soundguy
use a paint pen and write the hours on the filter when you change it, you always know where your at that way. Check your fluids before you head out and ALWAYS look for signs of leaks before you start out and while your working. Spotting a sudden wet spot on the dirt saved me from certain engine damage on an old 175 we had, block had cracked due to a bolt had backed out on the loader and I was leaving a trail.
keep fuel cans clean and new, always have extra oil and hydro fluid on hand in case of a situation.
/ OPERATIONAL TIPS FOR NEWBIES #114
Yes I would say,..perhaps even more important to check for leaks,..."On a Brand New Tractor". The first few weeks using the loader, I tightened several hydraulic line connections that "began-leaking-with-use".
Just guessing here, but "perhaps" coming down the assembly line, they get connected quickly and perhaps quickly snugged up with a wrench,.....BUT probably not "always" given that extra careful "tightening" that "time-on-the-line" doesn't allow for??
Naturally I'm guessing at this as I've not been on the line, but knowing that speed is usually a "line" factor,...it seems "possible"??
Also,...(having done pre-delivery), I assume many dealers do a fairly thorough "pre-delivery" but cannot be expected to check each and every connection. Even if they did, you can't always tell,...it's amazing how tight a connection can seem and still leak under pressure!
So my advice to "new" tractor owners,...whether it's new or used, but "new" to you,... For a while, keep a "real" close watch for drips, leaks or dirt sticking somewhere it shouldn't. Check to see if it's oily? I carried wrenches that fit the lines for a while. Seems ok now. Good luck with your maintenance as it is an important part of tractor "Problem-Avoidance"!!!
AND,..of course, some "tug-safety-tips": Make sure your hydraulics are ..DOWN.. and ..RELAXED, ..."prior" to tightening!!!!! Cuz, "IF" you accidentally strip the thread or twist/break/rupture a line,.. the loader, 3 pt etc could DROP down "instantly" and injure you severely!!!!
Best Wishes,
. . tug
1 real good way to find a leak, or check for a leak is to clean the area real good and dry it off, then sprinkle baby powder over the suspected area. Then run the unit, the powder will show the fluid very quick. There is a spray can available for this made by Kent that i have used several times.
/ OPERATIONAL TIPS FOR NEWBIES #116
Just a little clarification:
$80 for a custom (can't find a ready-made one to fit a hitch ball snugly into the drawbar around here) bushing = cheap??
Only pulling trailers around the yard with the 3-pt. adapter. Any real hard pulling, I plan to do with the drawbar.
Always wear my seatbelt :)
/ OPERATIONAL TIPS FOR NEWBIES #117
80$.. wow.. somebody saw you coming!
can't recall where.. but I've picke dthem up before for not much more than pocket change..
soundguy
/ OPERATIONAL TIPS FOR NEWBIES #118
For a hard pull you want a clevis, not a ball anyway. Getting a good attachment to a ball with a chain is not nearly as easy as a clevis.
/ OPERATIONAL TIPS FOR NEWBIES #119
if it's broke, fix it promptly and correctly. don't rush. change fluids when recommended.
/ OPERATIONAL TIPS FOR NEWBIES #120
...parked the machine for the night, left the blade in the "up" position, climbed down and went home. A while later some of the local kids came by and began climbing on...
Years ago I was one of those types pf kids, climbing onto stuff I should not be climbing on. A bunch of friends and I we playing around a large crane that was parked in teh school parking lot overnight. The crane had a wrecking ball on it raised 30-40 ft up. One of the kids got up into the cab, while the rest of us played "chicken" under the ball. Yeah, stupid things kids do. As predictable, someone yanked on a lever and down came the ball. Fortunately no one was under the ball at the time. We ran like heck to get out of there. Now its 30 years later and every time I see a wrecking ball I think of that time.
2022 EZ-GO ELITE...
CATERPILLAR D6R XL CRAWLER DOZER (A65053)
CATERPILLAR D6R XL...
2022 CATERPILLAR 272D3 SKID STEER (A65053)
2022 CATERPILLAR...
2022 EZ-GO ELITE...
2018 Ford Explorer AWD SUV (A64557)
2018 Ford Explorer...
2010 Ari Hetra HDML-8 15,000lb. Heavy Duty Mobile Column Lifts (A61572)
2010 Ari Hetra...
