Operating Tips
   / Operating Tips #1
BobRip
Elite Member
Powhatan Va.
2000 Power Trac 422
I would like to start a thread that gives operating tips for the PT. I don't thing this has been covered before, except as scattered over many threads. Please keep these short. Thanks
My favorite is the PT wiggle. If you are stuck in mud or can't make it up an incline or need a little more force to push a bucket you can steer left and right while applying power to the wheels. I can climb about a 25 degree slope with my 422 using this technique. It's slow, but faster than using my boat winch.
   / Operating Tips #2
Steering wheel spinner knob!
I'll chime in with perhaps the most important item for a new user to get. Need to forget that there is even a steering wheel on these articulated machines since they do not respond like a regular vehicle or tractor.
Get used to the "one handed cranking movement" .....just look where you are going and crank away.....much smoother and more natural movement than trying to "steer" like a regular vehicle.
   / Operating Tips #3
If you don't have solid tires on your mower(s), keep them inflated to whatever the sidewall says is the max pressure. Check them frequently, and you won't garner so many mower flats.
Do something about those idiotic inner valve stems before you rip one out, especially if you rough mow or brush hog.
Build an adapter to use a standard hitch receiver on the rear. Pin hitches are a lousy way to tow anything, especially if you have hilly terrain.
   / Operating Tips
Like this one attached.
   / Operating Tips #5
Here's one that someone on here suggested when I first started can't remember who now. Most people don't think it's worth trying, but I now swear by it.
When you accidentally leave put your left foot on the treadle peddle, and jump the PT back about 4 ft before you realize what's going on.
Try this method, just put your toe under the right peddle instead of pushing down on the left peddle, and raise up on the right peddle. Very precise control over reverse.
Since I have been using this method I haven't jumped the PT once, and backing into the garage or in tight spaces it gives me much better control.
   / Operating Tips #6
I know this one will be controversial -- but for most work, I like to leave the throttle at somewhere around 75-80% instead of full throttle -- I'm guessing about 2800-3000 RPM. The tilt circuit, especially, is much smoother at this RPM, and not nearly as sensitive and jerky...
I only run full throttle if I'm using the PTO (finish mower, rough-cut mower, etc.) or if I need the wheelmotor torque to climb hills or to dig, push into piles, etc.
IMO, this RPM puts the engine near the top of its torque curve and still will not overheat it as long as you don't lug the engine. As I began with, I know this is controversial, and may not be totally in synch with other recommendations or operating instructions.
   / Operating Tips #7
My 425 doesn't have the more sensitive treadle controls of the newer machines, and I've read lots of tips about how to manage that sensitivity (lift with toe, add springs, etc.). I don't have a problew with "over-sensitivity" but that may be a factor of the mechanical controls and not my technique.
I operate mine with BOTH feet on the treadles at all times, just like flying an airplane with both feet on the rudder pedals. When I press down on either side I must provide enough pressure to "pry up" the opposite foot and leg. I NEVER operate the PT with only one foot, because I consider pressure on the opposite treadle to be my "brakes"...
If you're operating your PT with only one foot, you may want to give this a try...
   / Operating Tips #8
Not quite. More like the one shown here. It requires no mods to the machine itself, and the pin hitch remains functional.
   / Operating Tips #9
We have different techniques for sure. That's what got me in trouble in the first place. I would have both feet on the treadle, my foot would slip off the right pedal and the weight of the other foot would floor it in reverse. I would be closing in on a tree before I realized what had happened to get er stopped. Since I've been using my toe it hasn't happened once. :rolleyes: I let the hydraulics be my brakes.
   / Operating Tips #10
That's the same thing I do. Your right I notice it does seem to run / operate smoother. ;)
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A51222)
2006 CHEVROLET...
2016 John Deere 35G Mini Excavator (A52377)
2016 John Deere...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A53473)
Ditch Witch 6510A...
2015 Volkswagen Passat Sedan (A51694)
2015 Volkswagen...
