Operating a gear tractor
/ Operating a gear tractor #1
Rowski
North Central Vermont, Jay Peak Area
2004 New Holland TN70DA with 32LC loader, 2000 New Holland 2120 with Curtis cab, 7309 loader
I know, I know, should have gotten/w3tcompact/icons/frown.gif a HST! Next time!
I have been experimenting a little on how to operate a gear tractor for loader work. I'm sure there is no right or wrong way, just different. I hope for some help on what is more effecient and better for the tractor.
What I have come up with:
1)Set the hand throttle to 1200 rpm, for faster hydraulics. and use the foot throttle. Let up an the foot throttle when shifting.
2)Set the hand throttle to 2000 rpms. Don't use the foot throttle. Just shift from forwad to reverse.
3) Set the hand throttle at or above PTO speed (2300 or higher). Just shift from forward to reverse. No foot throttle.
As most of you know this for pushing back snow banks. I am in a low gear, not the lowest. I do use the differeential lock quite a bit, I do have chains on the rear wheels with a 55 gallon drum full concrete on the 3pt hitch.
#2 seems to work better for me.
Would the engine use less fuel running at 2000 rpm than always throttling up and down?
I'm going to be putting about 20 to 25 hours on the tractor this week for snow removal.
FREE SNOW... BRING YOUR OWN TRACTOR, PLAY ALL YOU WANT!!!!!
Derek
/ Operating a gear tractor #2
Derek,
I found out when I use to plow w/Farmall H, tight tire chains&half throttle {about 2 grand}& keep the left foot ready for the clutch,for this keep up w/hydraulic gpm plus traction...and by doing this the clutch didn't smell nor damage.
Gear tractor do have there advanages over HST when pushing snow banks back also on ice. /w3tcompact/icons/wink.gif
Thomas..NH /w3tcompact/icons/wink.gif
/ Operating a gear tractor #3
Derek, I have yet to operate an HST other then trting it out in the dealers yard. I liked it alot and can see its benefits. When I use a shuttle shift tractor, I never set the throttle to any speed, I only use the pedal, part of this is because that is exactly what allows me to use this tractor much the way one might use an HST. While backing away from a pile of material, I am still rolling backwards when I go to idle and shuttle shift with no clutch, I can feel the hydraulic clutch slowly engaging itself for my forward motion which is when I'll put on some RPM's. All this takes place with no jerking and the least engine RPM. I don't need much GPM from the pump because I have my bucket and loader already in position from backing out at close to full throttle. If I'm loading a truck though, that is not enough time to fully raise the loader and I have an extra step. I do realize that the tractor I'm using may be quite different then yours and this method, if it is even understandable may not work with yours. The tractor I use has a wet clutch which means its always in oil, runs cool and is silky smooth. It ain't HST, but its the next best thing, Rat...
/ Operating a gear tractor #4
I've got a gear JD and have done quite a bit of box blade work in the last few days and have been using your method 1. It works best for me since my tranny shifts a little easier when I let off the throttle. My biggest problem is I need one more arm or leg to work the differential lock since all my other limbs are busy clutching, steering, shifting, throttling and braking!/w3tcompact/icons/smile.gif
Boots
/ Operating a gear tractor #5
Hey Derek, This is the way I do it. Put it up in high RPM, let the clutch out slow. When you feel the tractor hit the bank and start to stop or log dowm roll your bucket up a little and keep going into the snow untill your tractor logs down or the wheels spin. Push in your clutch and decrease idle so you don't get a big jerk going backwards.At this time your probably in as far as you can go. Hope I got this down right. If not all the other reply's sound good too!!!!! It'd be allot easier to explain when we get together again.
Pushing snow in the morning with the 1720
Al
/ Operating a gear tractor #7
Derek:
I use your method #1 on my Kubota B6100DT. In fact, I may be setting the hand throttle a little lower than 1200RPM - don't know, I don't have a tach.
I like this method because it lets me control the speed/power of the tractor by using the foot throttle. If I need to raise the FEL while moving, I have plenty of RPM for the hydraulic pump.
I've never driven an HST and I know that most people here sing their praises but I just think it would be wierd to have the engine blasting along at high RPM all the time regardless of how fast you're going or how hard you're working the tractor. I like the fact that when I'm sitting stopped, resting - so is the engine. To me, the GST or shuttle shift would seem like the best compromise - but I've never driven one of those either.
/ Operating a gear tractor #8
My Previous tractor was not a HST & I typically used your method #1 with most success. I always felt that letting off the throttle while shifting helped the lifespan of the clutch. (when replacing it requires a tractor split you don't want to do it any more often than you have to) It also helps to give you a little extra control for your speed as well. You don't always want to hit a bank going wide open... sometimes plow parts break if you catch some frozen ground too fast at the wrong angle under the snow bank. I always thought that it allowed me to feel things out a little better if I could hear the engine start to labor a little. You won't hear that as much if your running wide open. It all comes down to personal preferance & what works best for you.
Troy
/ Operating a gear tractor #9
I operate most of the time using your option #1. I can't bring myself to let the clutch out with the RPMs any higher than that... I prefer to engage the clutch at low RPMs and then give her some juice. I've split tractors before to replace clutches, and don't want to do it again if I don't have to/w3tcompact/icons/smile.gif. My Cub is a straight gear job, no shuttle shift.
Corm
/ Operating a gear tractor #10
I have two choices, either get a big pair of clown shoes to operate the diff lock and the gas pedal, or keep a big stick in my mouth for the diff lock! Someday compacts will have a nice electric diff lock on the steering wheel or loader control!
/ Operating a gear tractor #11
I have a shuttle shift Ford, an HST BX 2200 and a GST Kubota L35. To me the biggest drawback of the HST is that if you want the power you have to have the danged rpm up which I HATE! Everything has advantages and disadvantages, we all seem to make our tractors work though.
Secondly, I haven't had much use for these moving graphics, email boxes that open and close, blinking words, etc, they all seem like worthless nonsense...
UNTIL NOW! Your operating loader is fantastic! Could you let an HTML neophyte in on it?
del
Well, I put in two days for tractor time. Monday and Wednesday. 10 hours straight each day. Plowed snow Tuesday 12 hours. Plowed snow Thursday and towing. Friday what normanlly is a 20 min. ride to work turned out to be 2 hr ordeal, then sanded the drive. Saturday sanded again all day! Maybe I can join the "mad shoveler" and get some of those white pills he was talking about.
Found that #1 works better 75% of the time. #2 is needed when using the differental lock, as del mentioned. Del, where can I get a pair of the clown shoes?
My legs are still sore from clutching and braking, a lot back and forth. Found out I get about a gallon per hour fuel comsumtion. Did do some slight damage to the loader will post what happened in a new post. Also found you get what you pay for when you buy chains. They didn't break just not as good of traction as I had wanted.
The thaw here was something else. Then snow banks are hard now and still have more loader work about 8 to 12 hours (depends on how hard the banks really are).
I got some pics of the snow removal being developed and will post them early next week.
Thanks for all the replies. It's nice to know there are still some gear heads out there!
Beat, tired, sore and over worked in VT
Derek
2018 Takeuchi TL10V2 High Flow Compact Track Loader Skid Steer (A64553)
2018 Takeuchi...
2019 Cadillac Sayers and Scovill 70IN Limo w Only 7729 Miles (A63689)
2019 Cadillac...
2009 Polaris Ranger 700 (A64127)
2009 Polaris...
UNUSED FUTURE ZP20-20'X30' ALL-STEEL CARPORT (A65055)
UNUSED FUTURE...
2015 SolarTech Silent Messenger Towable Solar Message Board (A64553)
2015 SolarTech...
UNUSED PARBREAK SST23 DEER SHAPED TARGET (A65055)
UNUSED PARBREAK...
