Open top culverts
/ Open top culverts #1
sros990
West Virginia
JD 990
Has anyone here built open top culverts to drain water from your gravel road?
How effective are the culverts and how did you build them?
Thanks
Steve
/ Open top culverts
Thanks
Steve
/ Open top culverts #3
Steve, if you send me a PM with your e-mail, I'll send you an article about them (and how to build them) from the Jan / Feb NY Forest Owner magazine. I have not built any of these, but can vouch for their effectiveness. They have to be maintained in order to function properly, which in part depends on your road surface and the sediment supply. Also, I suggest armouring the outlets--water flowing out of these things can be moving with relatively high velocity/energy. Good luck!
/ Open top culverts #4
/ Open top culverts #7
I went to Google and did a search on open top culverts and found quite a bit of information on them. I have a couple of places on my property where I am going to give them a try. Sounds like a great idea in areas where a standard culvert won't do what is needed.
Farwell
/ Open top culverts #8
Farwell
2006 LeeBoy L8510R Low Deck Asphalt Crawler Paver (A66734)
2006 LeeBoy L8510R...
2014 Dodge Grand Caravan Van (A66738)
2014 Dodge Grand...
LINCOLN ELECTRIC POWER MIC WELDER SETUP (A67714)
LINCOLN ELECTRIC...
1996 INTERNATIONAL (INOPERABLE) 4700 (A67714)
1996 INTERNATIONAL...
2020 ISUZU NRR BOX TRUCK (A67714)
2020 ISUZU NRR BOX...
6 1/4 INCH OD 90 DEGREE ELBOWS (A68842)
6 1/4 INCH OD 90...
