Open Centre ??
/ Open Centre ??
Kenny when you say diverter on the main line from the pump do you mean on the tractor hyd. system or on the pto / backhoe pump ?
/ Open Centre ?? #13
I meant the PTO pump because you said this:
reroute hyd. fluid to a woodsplitter mounted on a Wallenstein backhoe attachment (pto driven pump)
/ Open Centre ?? #14
I just watched the video...NOW I UNDERSTAND WHAT YOU ARE TALKING ABOUT!:eek:
That is a pretty neat setup! I was thinking you where just trying to power a stand-alone splitter with the PTO pump.
/ Open Centre ?? #15
Why not just put a set of quick couplers on the bucket curl cylinder? position it where you desire then coupler the hoses from that cylinder to your wood splitter.
Ken
/ Open Centre ??
Splitter in that video is a very nice setup in my mind at least !
Sorry for the confusion Kenny . I had originally planned to build a stand alone splitter powered by tractor hydraulics . However if my GX700 attachment will support a backhoe mounted splitter (as in the video) that would be my choice of build .
With that in mind , in your opinion is the diverter from Princess Auto capable of doing what i want to do?(provided whatever i buy matches the pump flow)
skidsteer.ca
Your idea is another option i would explore . However being able to tilt the splitter beam could be quite useful so i hesitate to give it up just yet .
/ Open Centre ?? #17
I just downloaded the catalog...
What you posted is not a diverter or selector valve, it is a spool valve and will NOT work as you are intending. It is designed to operate a cylinder electrically.
What you need is listed on page 25 (manual) or page 26 (electric). 2-position, 6-way Selector valve.
They will take ONE input (from the BH control valve) and DIVERT, or SELECT between one of two outputs (bucket or splitter)
/ Open Centre ??
Perfect !
Think i'll opt for a manual selector ( "C" from page 25 ) and eliminate possible wiring problems somewhere down the road .
Thanks Kenny !
5th Wheel Hitch (A59230)
5th Wheel Hitch...
CATERPILLAR 255 SKID STEER (A52709)
CATERPILLAR 255...
2019 Ligchine Spiderscreed Concrete Screed (A59228)
2019 Ligchine...
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
2018 Caterpillar 308E2 CR Excavator (A61166)
2018 Caterpillar...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A59230)
Pallet of...
