Oops!
/ Oops! #1
BIKER BOB
Raymond, Maine
Mahindra 3215
Well it finally happened, I flipped my tractor. Yesterday I was using my logging winch to move a recently cut tree from my yard when the log took a sudden roll on an incline and yanked the tractor over onto its side. It was with great fortune (and luck ) that no one or nothing was hurt other than a couple of scratches on the ROPS. After about an hour and a couple of winches I was able to get it back on all four tires like it is supposed to be.
It was a valuable lesson to pay closer attention and use caution with such a powerful tool. Luckily it happened close enough to home and enough tools to make the recovery a bit simpler.
It was just one of those days! Glad nobody got hurt and all is well again.
/ Oops! #2
Glad nobody got hurt. Those split second things often are good/bad luck difference between life and death.
Cleaning ice off my windsheild ths winter and a power line snapped 1 pole down from where inwas standing. If ot snapped at the pole i was standing next to i probably wouldn't be here writing this. Stuff like that really helps a guy slow down amd think more.
/ Oops! #3
Good your okay..whew,couple of scratches not bad..not bad all of what could have been nasty.
/ Oops!
Yup, the only thing that really got hurt was a bit of pride. The only other person around was son in law, and fortunately he was far enough away from the mayhem that he was in no danger. Stuff happens pretty fast sometimes.
/ Oops! #5
Bob I saw you all over the evening news!
Kidding, sometimes an accident with nobody hurt and little to no damage is a good thing, I've had my share of them and close call's, and there's no better permanent learning tool. Glad to hear that you and your machine are OK:thumbsup:
and for this one, you are excused for no pics :drink:
/ Oops!
Ya, the last thing on my mind at that time was taking pictures, looking back I kinda wish I had taken a few as a reminder. Not that a reminder is needed! :eek:
/ Oops! #7
I guess it wasn't hydro-locked when you restarted it? Apparently, as I've learned on TBN, that's a thing. :confused3:
Glad you are ok. Out of curiosity, seat belt and ROPS up?
Edit: it just occurred to me that you probably were not in the seat. Nevermind.
/ Oops!
Only spilled a couple of quarts of fuel and about a quart of oil. I let the tractor sit upright for a while before starting and after checking all fluid levels. Guess I got lucky with the "hydro lock" thing. I have also heard it is a real thing, just happy it did not happen to me. Had it back on it's wheels in about 40 min to 1hr, quite surprised and happy that a 2000 lb elec. winch and a come-a-long righted it.
/ Oops! #9
Glad to hear your ok!.....I had a Ditch Witch trencher do that to me a good 15 years ago....bing,bang,boom......not something you want to be involved in or even be just standen around by!!!
/ Oops! #10
Now i'm going to have to search TBN for hydro lock.
Glad you and the machine are all right
/ Oops! #11
Hydro locking is when an engine is flopped or turned over oil from the crankcase flows past the rings and into the cylinder. You can also hydrolock an engine by going into water that's too deep and water is sucked into the intake and then the cylinders. Since liquids don't compress when the piston comes up on a compression stroke there is no where for anything to go so something has to give as in pistons, rods (usually) etc. Often a rod breaks off and pokes a hole in the block. Any kind of hydro locking whether it's from crankcase oil, fuel or water though the intake of coolant will ruin your day so avoid it if at all possible.
/ Oops! #12
Bob, glad you're safe!!!
I may have missed it: Where were you specifically when it went over? Were you in any danger when it happened?
Good luck!
KIVEL 3500 PALLET FORK ATTACHMENT (A61572)
KIVEL 3500 PALLET...
iDrive TDS-2010H...
2023 SANY SY225C EXCAVATOR (A63276)
2023 SANY SY225C...
2024 ANKONA 54" HANG-ON WHEEL LOADER FORKS (A62129)
2024 ANKONA 54"...
John Deere 4300 32HP Front Loader Utility Tractor (A61572)
John Deere 4300...
JOHN DEERE 8330 TRACTOR (A63291)
JOHN DEERE 8330...
