OOPS its stronger than that.
   / OOPS its stronger than that. #11
how much does Rim Guard cost? I have heard ppl having good luck fighting flats when adding tire sealant (like slime) to rimguard. I want to ballast our 2810, but I need it to resist tiny punctures (cactus needles mainly). Which the current sealant is taking care of nicely.
Texan4life: Can 't say how this will work for fighting small puntures, but for what it's worth, I have a tire shop nearby that services a lot of private owner's tractors locally. He sent his guy to fill my rear tires on my 5035 with beet juice, of all things! Was about 60+ gallons per tire (but don't quote me) and he charge me $450 cash. I believe he said it would add about 1200+ lbs (again, don't quote me) to the rear of the tractor. I'm pretty sure I saved some money there and God forbid, if you ever have a leak/flat, the beet juice is non toxic so don't worry about the EPA coming after you. :(
Either way, it's a good idea for both traction and safety. I scared myself a couple of times moving heavy processed gravel around my steep driveway with a bit of a pitch to it and the rear got a bit "light". :eek: Solid as a rock now.
Cheers
Wow this tractor can put it to the ground. I have found the next weak spot in my ripper/subsoiler and it's a good one this time. Oh well I think I will just start from scratch and build it all around heavier. On a good note I was pulling out 5-7 inch dia. roots with it so not too bad.
Also found that the Kodiak heavy duty box blades have a breaking point while popping out a couple trees. I broke the two further back bolts that come from the top link down to the box(Not ramming stuff just butting up against and lifting 3pt while pulling) but I am darn impressed w/ the strength of this machine it really puts the power to the ground as compared to a skid steer.
This makes clearing along the fence fun. I just need to build my attachments heavier than I thought.(Never figured on bending steel that thick:thumbsup:)
On a good note the blade I reinforced is working nicely but now I am thinking I should have gone ahead and made it wider and just bought a 7 or 8 foot cutting bit for it. Oh well something to look forward to buying or building in the future.:drool:
   / OOPS its stronger than that. #13
EMB5530,
As stated in my earlier post everything I have for my 5530 is HD or XHD. I have used my Bison 242 96" back blade with hydraulics to shear 8" pine trees below ground surface. :thumbsup: But now I have to contend with the roots if I plow in that area of the land. :eek:
Idaho2
EMB5530,
Idaho2
Pine trees have nothing on Osage Orange:cool:. Its the difference between hardwood and softwood. Thats the reason I take my ripper and run it through the roots b4 trying to remove the tree as you will simply not split/break it off at the ground it comes w/ roots and all. My friend, I would be willing to bet you would have a hard time not bending anything not built w/ extra reinforcement(more than factory) if you have ever encountered this type of tree. I have added more strength to one blade b/c of this and am now planning on reinforcing my entire fleet of implements to handle the extra abuse from my(Proudly Said)heavy duty machine. But I have 2 pine trees that need to be removed on my property and I'll get back to you after I take the two out. Maybe they do compare to hedge(Osage Orange). Truth be told though, I had an easier time getting the hedge out w/ my tractor than I have when I borrowed an 853 bobcat which surprised me. Have to keep digging and digging to get them out w/ a skid steer. Earlier today I took a friend of mine, whom has farmed his entire life, around the property(just walking around b s ing and enjoying a couple of beers in the nice weather) and he asked who I knew w/ a small dozer until, in front of one of the larger trees he saw 4 deep tire marks(the implement breaker):ashamed:. Then he just looked at me, smiled and said lets see your new toy that you think is a dozer (hadn't seen my tractor yet as we had not seen each other since Oct.).
   / OOPS its stronger than that. #15
EMB5530,
After reading about the Osage Orange I'll stick with the Pines. Those things are nasty from what I read. I now also see why you have a tire puncture concern. You're right no comparison with the Pines.
idaho2
2022 Case TR340B Skidloader (RIDE AND DRIVE) (A50774)
2022 Case TR340B...
2021 Case IH Magnum 240AFS CVX Connect MFWD Tractor (A50657)
2021 Case IH...
2023 Ford Explorer AWD SUV (A48082)
2023 Ford Explorer...
2013 Chevrolet Impala Sedan (A48082)
2013 Chevrolet...
2013 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A48081)
2013 Chevrolet...
Mitsubishi FG15 Forklift (A50860)
Mitsubishi FG15...
