ONLY use USA Made Tubes in Tires for Fluid applications
   / ONLY use USA Made Tubes in Tires for Fluid applications #1
Brown Dog
North GA
John Deere 5115M 5101E H260 5115M 540M all MFD
Pay a little more the first time & be Done with the job.
I put fluid in all 4 of my tires for traction on hills & a 1400lb 110" Rear Finishing Mower.
I've got my rear 44x18-20 Turf Tire back at the tire store for the THIRD TIME.
Cheesy THIN imported tubes splits wide open FIRST DAY of use & looses $50 of antifreeze EACH TIME.
Just a FYI :D
   / ONLY use USA Made Tubes in Tires for Fluid applications #2
Prolly shouldn't put anti-freeze in tires. Windshield washer fluid is better and considerably cheaper. I use it with no inner tubes.
   / ONLY use USA Made Tubes in Tires for Fluid applications #3
Where do you buy USA made innertubes? Can't say that I have seen them.
Most all Tractors with FEL's need fluid in rears :D
I WOULDN'T want water on my steel rims - running tubeless.
Bridgestone / Firestone tubes are USA natural rubber - thick & heavy unlike Korea & China THIN JUNK.
   / ONLY use USA Made Tubes in Tires for Fluid applications #5
I run Rimguard in my rears tubeless.
The last set of Firestone tubes I bought for my fronts were thick and heavy but they were made in Korea. The Taiwan and China stuff is junk.
My rear was Korea too & it was thin as a a small Lawnmower tube :-((
It split WIDE OPEN with 8psi & half full of water / antifreeze mix.
Tell me more about this Rimguard you speak of :
2006 Isuzu NPR 16FT Box Truck (A50323)
2006 Isuzu NPR...
New Swict 60" Skidloader Bucket (A50774)
New Swict 60"...
2023 JT8 - 5' X 8' TILT TRAILER (A51243)
2023 JT8 - 5' X 8'...
2013 Ford E-350 Enclosed Service Van (A50323)
2013 Ford E-350...
UNUSED AGT MXMRW14 STAND ON WHEELED SKID STEER (A51243)
UNUSED AGT MXMRW14...
2006 Ford F150 (A50323)
2006 Ford F150...
