ONLY use USA Made Tubes in Tires for Fluid applications
   / ONLY use USA Made Tubes in Tires for Fluid applications #1
Brown Dog
North GA
John Deere 5115M 5101E H260 5115M 540M all MFD
Pay a little more the first time & be Done with the job.
I put fluid in all 4 of my tires for traction on hills & a 1400lb 110" Rear Finishing Mower.
I've got my rear 44x18-20 Turf Tire back at the tire store for the THIRD TIME.
Cheesy THIN imported tubes splits wide open FIRST DAY of use & looses $50 of antifreeze EACH TIME.
Just a FYI :D
   / ONLY use USA Made Tubes in Tires for Fluid applications #2
Prolly shouldn't put anti-freeze in tires. Windshield washer fluid is better and considerably cheaper. I use it with no inner tubes.
   / ONLY use USA Made Tubes in Tires for Fluid applications #3
Where do you buy USA made innertubes? Can't say that I have seen them.
Most all Tractors with FEL's need fluid in rears :D
I WOULDN'T want water on my steel rims - running tubeless.
Bridgestone / Firestone tubes are USA natural rubber - thick & heavy unlike Korea & China THIN JUNK.
   / ONLY use USA Made Tubes in Tires for Fluid applications #5
I run Rimguard in my rears tubeless.
The last set of Firestone tubes I bought for my fronts were thick and heavy but they were made in Korea. The Taiwan and China stuff is junk.
My rear was Korea too & it was thin as a a small Lawnmower tube :-((
It split WIDE OPEN with 8psi & half full of water / antifreeze mix.
Tell me more about this Rimguard you speak of :
Komatsu D39PX-24 Crawler Tractor Dozer (A49346)
Komatsu D39PX-24...
2020 Toro 6000 Series 60in Zero Turn Mower (A50322)
2020 Toro 6000...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
2011 PETERBILT 337 (A52472)
2011 PETERBILT 337...
UNUSED JCT SKID STEER QUCK ATTACH 72" BRUSH CUTTER (A51244)
UNUSED JCT SKID...
(30) 9' Pipe Fence Posts (A50515)
(30) 9' Pipe Fence...
