Only Orange for this mountain man
   / Only Orange for this mountain man #1
dmiele
Morgan County, WV
Kubota B3300SU
Have been reading for awhile with you guys, decided to join. Wealth of info, great site!
Me, old 54, young at heart. Bought a B3300SU with hoe Jan this year, my 4 year old grandson made me after selling my 555 Ford. Thats my story and me and him are sticking to it:laughing:
Have done alot with this little tractor, perfect size now I have the property cleared.
Been haveing an issue with the pedal safty switch and finally just stopped at 90 hours yesterday, any help would be great. Pics as soon as I can get it going again
   / Only Orange for this mountain man #2
Welcome to TBN. :)
   / Only Orange for this mountain man #3
WELCOME to TBN :)
I moved your thread to the Kubota Owning/Operating Forum.
   / Only Orange for this mountain man #4
Sorry I can't help you with your problem, but welcome to the forum.
   / Only Orange for this mountain man #5
It's a common problem with the B-series but also an easy fix. I assume your HST pedal isn't returning to neutral and therefore won't let the tractor start? If this is the case the culprit is the little rod that pushes the safety switch to tell the tractor the pedal is in neutral. It rides in a little tube and that tube can get corrosion in it. This whole assembly is right above and behind the pedal pivot (also make sure to grease the pedal pivot) Some light oil or grease sprayed into the tube should fix the problem. If you want to disassemble it coat it with light grease, if not shoot a little WD40 in there. My B3200 has a little over 400hrs on it, only had the problem you are experiencing once, after a little oil it hasn't reoccurred.
   / Only Orange for this mountain man #6
Welcome to the family!
2009 FREIGHTLINER BUSINESS CLASS M2 CRANE/POLE TRUCK (A51406)
2009 FREIGHTLINER...
JOHN DEERE LOT IDENTIFIER 109 (A53084)
JOHN DEERE LOT...
Landoll Hauloll (A53472)
Landoll Hauloll...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
JOHN DEERE 8245R LOT IDENTIFIER 263 (A53084)
JOHN DEERE 8245R...
DEWALT 4400 PSI GAS PRESSURE WASHER (A51248)
DEWALT 4400 PSI...
