one stroke engine
/ one stroke engine #1
talktokc
what is the difference between one stroke engine and two stroke engine
/ one stroke engine
what is the difference between one stroke engine and two stroke engine:confused:
/ one stroke engine #4
Uh difference is one doesnt exist. There are 2 strokes and four strokes.. 2 strokes make power every revolution and 4 strokes make powere every other due to cams intake and exhaust valves.
/ one stroke engine #6
Did you mean one lung, as in hit and miss?
I know there's a whole community devoted to those gizmos.
/ one stroke engine #10
A piston engine must have at least two strokes. The piston goes down, one stroke. The piston goes up, second stroke.
Two stroke engines have two strokes power=down compression =up.
Four stroke engines have four strokes: power= down; exahust = up; intake=down 2nd time; compression=up 2nd time.
Dunnow maybe a rotary engine could be a one stroke. But it actually has four phases which are for all practical purposes strokes.
/ one stroke engine #12
One that stops after 1/2 revolution.:D
/ one stroke engine #16
There are several designs of 1 stroke engines. They accomplish all 4 regular cycle stages in 1 revolution, usually involving multiple pistons in 1 cylinder. A Sterling cycle engines comes to mind. There are others....
2017 Ford Fusion Hybrid Sedan (A61574)
2017 Ford Fusion...
2006 Ford F-350 4x4 Crew Cab Pickup Truck (A61573)
2006 Ford F-350...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2014 GENIE S-40 TELESCOPIC BOOM LIFT (A64279)
2014 GENIE S-40...
60" EXCAVATOR RAKE (A64279)
60" EXCAVATOR RAKE...
John Deere 4960 Tractor (A64047)
John Deere 4960...
