One cylinder intermittently not firing
   / One cylinder intermittently not firing #11
Okay.
Let's put 50 hours on the machine. Why would it now start with sticking guides instead of doing so in the first or second run-in period? There's more play in them now than there ever has been.
I'd buy into a broken or weak valve springs if that engine make had a history of putting garbage materials into their product, but sticking valve guides well after the break-in period.....nah, you're just pulling my chain. Right?
   / One cylinder intermittently not firing #12
Okay.
Mine did it at ~250 hours. The guides are pressed into very cheaply cast aluminum heads, and they come loose.
   / One cylinder intermittently not firing #13
Then you were also sucking oil like crazy?
The engine has less than fifty hours, but was out of warranty by one week when the problem showed itself. Yes I have swapped coils, but have not run it enough to CONFIRM that the problem stayed in the same cylinder.
On another forum, someone familiar with this engine said that I should do a compression check when cold and again when hot. He thought that the spitting and popping in the exhaust after warm up was due to a valve too tight. I am not certain that this is happening only after warm up, but it might very well be. If he is correct with this hunch, I don't want to run it very much for fear of burning a valve. He also said that the valves are a pain to adjust since it is done with shims.
Remember, this is an intermittent problem.
I want to thank everyone a BUUuunnch for their replies and thoughts. I am about to take a little short vacation with my wife and it will probably be late next week before I get back to this.
   / One cylinder intermittently not firing #16
Failing or weak valve spring is what I suspect he's thinking. Either valve spring or a air, oil or coolant leak.
   / One cylinder intermittently not firing #17
Hmmm,
So could you salvage the head with some over sized guides? Or was it just scrap and having to renew the head?
   / One cylinder intermittently not firing #18
Sounds like a bad coil pack
2018 John Deere Z997R (A53317)
2018 John Deere...
2015 Freightliner M2 106 AWD Altec DM478BTR Insulated Digger Derrick Truck (A60460)
2015 Freightliner...
JMR STUMP/ TRENCHING BUCKET (A56857)
JMR STUMP/...
2015 JOHN DEERE 35G EXCAVATOR (A52707)
2015 JOHN DEERE...
2019 Ligchine Spiderscreed Concrete Screed (A59228)
2019 Ligchine...
Kubota MX5400 land mgmt package
Kubota MX5400 land...
