One cylinder intermittently not firing
   / One cylinder intermittently not firing #1
MBDiagMan
Sumner, Texas
John Deere 5045D, Grasshopper 61" with PowerVac,Gator 825i, Cub Cadet 2145
I hope you guys won't mind commenting on the problem I'm having with my John Deere Gator 825i. I have a reasonable amount of experience troubleshooting EFI car and truck engines, but this one is a little different.
This buggy has an 825cc. Chery, 3 cylinder EFI engine. It has individual coils on the end of the engine. There is no indication of a code being set, but although my scanner will connect to the connector under the dash, it turns out that John Deere has proprietary software so my scanner won't work.
One month after the warranty expired, it developed a missing cylinder. I pulled the plugs and found the center one fouled. I cleaned it and the miss went away temporarily.
I then used a stethoscope while it was missing and could hear all the injectors clicking normally. Although in my fifty years of messing with engines, I've only seen one spark plug that was actually bad, I swapped the number one and two spark plugs and the foul stayed with the center cylinder.
I then swapped the coils between number one and the center cylinder and gave it a hard run. After it warmed up real good it began missing. I brought it back to let it cool before pulling the plugs and thought sure that I would see the number one plug fouled instead. It had been intermittently running well, and what I found was traces that the center cylinder had tried to foul, but couldn't confirm.
I plan on giving it another hard run to see if I can get a consistent foul so that I can confirm which cylinder is now fouling, but at this point it appears that the center cylinder is the culprit even with the swapped coil, but remember, I have not totally confirmed this.
Also, when running it at speed, when the miss develops, I get a popping and snapping from the exhaust, which seems to indicate that unburned fuel is making it into the exhaust and causing this.
Any experience with a similar situation?
Thanks for sharing your savvy and experience.
   / One cylinder intermittently not firing #2
As I was reading your post the 1st thing that came in my mind was bad valve guides in that cyl.
   / One cylinder intermittently not firing #3
What kind of fouling? Oily or lamp black soot.
You could do a compression test for giggles.
But I think your next stop is fuel pressure, then think about #2 injector.
   / One cylinder intermittently not firing #4
Consider new wires to the effected cylinder?:)
Thanks for the replies!
The engine is near new and I just can't imagine valve guide trouble. Since it is not an oily foul, it seems to rule it out even more. When fouled it looks black, but not sooty black. More of a wet black.
There is no mechanical connection for checking fuel pressure. I expect that it is tested through the ALDL, but as I said I don't have the proper software.
I too suspect the ignition wire and want to run it some more until I get a definite foul before putting a wire on it.
Since it is popping in the exhaust when this happens, it seems that it is putting raw fuel through that cylinder and popping in the hot exhaust.
My wife and I are leaving Saturday for a short vacation. I probably won't get a chance to run it anymore before the end of next week. I will report back then.
Thanks again. I was hoping someone had seen something like this before. I still tend to believe that the problem is on the ignition side, but intermittents always seem to make me think things that don't turn out to be correct.
Any further comments are welcome and very much appreciated.
   / One cylinder intermittently not firing #6
But but but, didn't you say you had individual coils per cyl.? And that you've already swapped them around with no change?
And yep, wet but no oil means fuel.
   / One cylinder intermittently not firing #7
If its a newer engine do you have a warranty?
   / One cylinder intermittently not firing #8
valve guides. one or both of the valves on that cyl are hanging open intermittently.
   / One cylinder intermittently not firing #9
Tight valve guides?!!!!!
Now after how many hours?
You can't be serious.
KOMATSU HM400-3 OFF ROAD DUMP TRUCK (A60429)
KOMATSU HM400-3...
2014 VOLVO A40G OFF ROAD DUMP TRUCK (A60429)
2014 VOLVO A40G...
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A58214)
2013 ORTEQ ENERGY...
UNUSED FUTRE FL-ESC220 ELECTRIC STONE CRUSHER (A52706)
UNUSED FUTRE...
2019 CATERPILLAR 320 GC EXCAVATOR (A60429)
2019 CATERPILLAR...
2003 Big Tex 10PI...
