Onan CCKA
/ Onan CCKA #1
jeffpardee
New Fairfield, CT
Log Splitter
A friend gave me an old log splitter with an Onan CCKA engine on it. It started to leak gas out of carb. and he took it off to fix. He never put it back on and water got into the cylinders. Is it worth trying to fix?
/ Onan CCKA #2
IMO yes. It will require a rebuild but if you don't encounter any other problems then about all you'll need to do is deglaze the cylinders after removing the pistons and an new gasket and probably a new sparkplug.
/ Onan CCKA #3
/ Onan CCKA #4
I have a CCK generator great units, I just wanted to tell you there is a lot of great information on the web site Smoke Stak under onan generators.hope this helps
/ Onan CCKA
Thanks for all the information. The engine just looks like it should be saved
2008 Chaparral 204 SSI Bow Rider Boat (A62613)
2008 Chaparral 204...
New/Unused CFG Industrial QK16R Mini Excavator (A65583)
New/Unused CFG...
2008 PETERBILT 365 (A65643)
2008 PETERBILT 365...
86 (A63290)
86 (A63290)
1974 Transtar 4300 Roll Back Truck (A65563)
1974 Transtar 4300...
2019 CAT 305E2 CR Mini Excavator (A62613)
2019 CAT 305E2 CR...
