Onan 140 having heat strokes
   / Onan 140 having heat strokes #1
Zoombah
Central Texas
The Onan 14 hp engine in my 2140 has a probem .... it dies after after 10-15 minutes of run time and will not restart for several hours. It has no spark when it has these episodes. After a few hours of cooling down it will then start and run just long enough to get it back into the garage.
What could cause this? It's like something in the ignition fails once it reaches a certain temperature.
   / Onan 140 having heat strokes #3
I have heard that onans had ignition problems. How old is it? If it has points and a condenser; condenser is probably bad.
   / Onan 140 having heat strokes #4
   / Onan 140 having heat strokes #5
I'm pretty sure all those Onan Elite 14's used in the CC's have a point-less electronic ignition module. The same engine is used on a lot of Onan generator sets, and from what I have read that module is a failure prone part.
-Fordlords-
   / Onan 140 having heat strokes #6
-Fordlords-
2007 Yamaha Rhino 660 (A55315)
2007 Yamaha Rhino...
2006 FORD F-250(INOPERABLE) (A53843)
2006 FORD...
2008 CAT 305C (A53317)
2016 Ford F-450 12ft Flatbed Truck (A55852)
2016 Ford F-450...
2025 SDLL30 Mini Stand-On Track Loader Skid Steer (A53421)
2025 SDLL30 Mini...
Adams 6Ton Hydraulic Lime Spreader (A57024)
Adams 6Ton...
