? on glow plugs
/ ? on glow plugs #1
whitearrow
philadelphia,ms
john deere 5203
i just bought a new jd 5203.i was looking in the owners manual and didn't see a section on glow plugs.do these tractors even have glow plugs?my dealer didn't mention them to me as to turn them on before cranking the tractor.he just told me to turn the key and crank it.if it does have them i know that i should be using them to save the starter some.although it does fire up pretty fast.
thanks,
whitearrow->>>-------------------->
/ ? on glow plugs
thanks,
/ ? on glow plugs #3
I am digging! I haven't found any reference. I can't see it even being needed in Mississippi, though....
/ ? on glow plugs #4
/ ? on glow plugs #5
Check and see if it has wires running to them on the top of the motor. My 4110 has them, but you don't turn them on, it is built in, to turn on when you go to start it. If you watch the dash, the lights go dim, and then after a very few seconds they get brighter, on mine that say the glow plugs shut off, to start it. But some has it some don't, so if the manual don't tell you, then you will have to look and see.
/ ? on glow plugs #6
/ ? on glow plugs
rockyridge,it does get cold here,20-30 degrees,during the winter months.just wondering,it works well the way that i am doing it for now,but it is also 90 degrees out.haven't had it in the winter yet,just purchased.
thanks,
whitearrow->>>------------>
/ ? on glow plugs
thanks,
/ ? on glow plugs #9
It is an option for your tractor like it was my 5320. Our tractors don't have glow plugs only an intake air heater. To use it you press the key in for a few seconds. If it gets under 32 degrees you may want to get one, however I have had no problem starting at 32 degrees or a little colder without using it.
The manual recommends to use the heater under 40 degrees Fahrenheit so you may want to invest in one.
/ ? on glow plugs #10
/ ? on glow plugs #11
OK, if it has a preheater, then it is direct injection, and doesn't have glow plugs. If it gets that cold, then a block heater might be a good idea.
/ ? on glow plugs #12
Land Pride Auger (A61166)
Land Pride Auger...
CATERPILLAR 299C SKID STEER (A62129)
CATERPILLAR 299C...
2023 Kubota L3560 Compact Utility Tractor with LA805 Front Loader (A63118)
2023 Kubota L3560...
UNUSED WOLVERINE RPR-12-72W 72" RIPPER (A62131)
UNUSED WOLVERINE...
2025 KH72 72in Hydraulic 4-Way Clamshell Bucket Skid Steer Attachment (A61567)
2025 KH72 72in...
2023 VOLVO VNL760 6X4 T/A  SLEEPER TRUCK TRACTOR (A59908)
2023 VOLVO VNL760...
