Oliver of a different type
   / Oliver of a different type #1
plastikosmd
Oliver bread slicer rehab for a friend
It shook it self to pieces. First identifying all the cracks and then cutting out the damaged area:
Removing rear housing and bearings where offset shaft runs
I’ve been scrounging for some 3/16 inch plate but haven’t found any therefore decided to finally just cut down some quarter inch plate using the shaper
Roughing cutter, single pass after flattening it out. Even with roughing cutter it leaves a good finish
Getting ready for layout
Video of shaper cutting
Hendy 12? universal shaper - YouTube
   / Oliver of a different type #3
Haven’t seen a shaper used in decades. My dad had a Smith & Mills bull wheel shaper, and a Cinci hydraulic one later. He had a couple of Hendy lathes.
I like them for this task (big flat facing.) Let it cut and I go do something else.
   / Oliver of a different type #5
We used to use them to cut profiles, moving the clapper box up or down, chasing the line. Lots of squaring up stock, sometimes slots. Lot of memories there. Never seen a Hendy shaper, only lathes. That machine looks to be in great shape, did you have to restore it?
Nope, came like that, I got lucky
It is the Cadillac of their (and all) 12 shapers
Auto feed on table and clapper, universal table so vise tilts, spins and rotates
I have some internal squares to cut, I don稚 have the shaper tool that accepts the bar to do this so I have to make that first
Cut to fit now to cut hole and weld in eccentric bearing stock
No thank u for having some interest!
I will cut the hole and weld in the eccentric bearing holder this weekend after a trial cut on the cnc
   / Oliver of a different type #10
Your friend own a bakery? I’d guess there aren’t a lot of bread slicer repair guys.
THERMAL ARC PREDATOR GAS WELDER (A54756)
THERMAL ARC...
2011 CHEVROLET EXPRESS SERVICE VAN (A51406)
2011 CHEVROLET...
UNUSED 4 GAUGE 25' JUMPER CABLES (A54756)
UNUSED 4 GAUGE 25'...
2015 PCI MFG. SOLUTIONS 130 BBL STEEL VACUUM TRAILER (A53843)
2015 PCI MFG...
Brent 640 Gravity Wagon (A50775)
Brent 640 Gravity...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
