oliver guy
/ oliver guy #1
todd smith
canada
oliver
Hey I have a 1365 oliver. Just bought it in summer now it just stopped. It started to knock near the back of motor and when I gave it fuel it died.It was leaking oil out behind starter so I think it's the back seal plus motor now. can anyone help me.
/ oliver guy #2
Welcome to TBN!
From your post I'm assuming it wouldn't restart either?
/ oliver guy #4
:welcome:
/ oliver guy #5
Welcome from Oklahoma.
No, with the information you've given it's not possible to help you. If you give details then someone may be able to answer your quiestion. Such as, did you run it low or out of oil; does the engine crank and not start or will it not crank; when you say you gave it fuel do you mean you advanced the throttle or did you pour fuel in the tank from a can, etc. Tell us what's going on, it's a waste of time if we have to just wildly guess.
Ken
/ oliver guy #6
Welcome to the forum. Did a bearing lock up???
/ oliver guy
It was using alot of oil.I kept on adding 1-1anhalf every time out. It started to knock loud then when I push on the throttle it just lost power and stopped. It turns over slow and doesn't start.
/ oliver guy #8
This does not sound good.
Spun rod bearing due to low oil level ?
Giyi Mini Pallet Forks (A62183)
Giyi Mini Pallet...
2013 Infiniti JX35 AWD SUV (A61574)
2013 Infiniti JX35...
2013 John Deere 4520 (A62180)
2013 John Deere...
2023 Unverferth 3PT 6 - FT Perfecta Field Cultivator (A63118)
2023 Unverferth...
LandHonor 65" Grain Drill (A62183)
LandHonor 65"...
24in excavator tooth bucket (A61307)
24in excavator...
