oliver guy
/ oliver guy #1
todd smith
canada
oliver
Hey I have a 1365 oliver. Just bought it in summer now it just stopped. It started to knock near the back of motor and when I gave it fuel it died.It was leaking oil out behind starter so I think it's the back seal plus motor now. can anyone help me.
/ oliver guy #2
Welcome to TBN!
From your post I'm assuming it wouldn't restart either?
/ oliver guy #4
:welcome:
/ oliver guy #5
Welcome from Oklahoma.
No, with the information you've given it's not possible to help you. If you give details then someone may be able to answer your quiestion. Such as, did you run it low or out of oil; does the engine crank and not start or will it not crank; when you say you gave it fuel do you mean you advanced the throttle or did you pour fuel in the tank from a can, etc. Tell us what's going on, it's a waste of time if we have to just wildly guess.
Ken
/ oliver guy #6
Welcome to the forum. Did a bearing lock up???
/ oliver guy
It was using alot of oil.I kept on adding 1-1anhalf every time out. It started to knock loud then when I push on the throttle it just lost power and stopped. It turns over slow and doesn't start.
/ oliver guy #8
This does not sound good.
Spun rod bearing due to low oil level ?
UNUSED JCT HYD AUGER (A62131)
UNUSED JCT HYD...
UNUSED RAYTREE RMSC78 - 78" HYD SOIL CONDITIONER (A62131)
UNUSED RAYTREE...
TORO TIMECUTTER SS3200 ZERO TURN LAWNMOWER (A62131)
TORO TIMECUTTER...
KUBOTA MS-111 TRACTOR (A62130)
KUBOTA MS-111...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
2007 JCB 520 LOADALL TELESCOPIC RT FORKLIFT (A62129)
2007 JCB 520...
