Oliver 1850
/ Oliver 1850 #1
ks oldtimer
mf 596
I am trying to help put a 3 point bale spear on an Oliver 1850. All the adjustments we have made seem to not help. Either the spear is pointing up when trying to back into the bale, which will not let the bale spear penetrate the bale, or the spear is point down when fully raised, letting the bale fall off. We have tried shortening and lengthening the top link, and adjusting the lift arms. None of this seems to work. I was wondering if maybe the lift arms might not be the right length, because the bale will raise but when it gets almost to the top that is when the bale leans back.
/ Oliver 1850 #2
Sounds like you are using a catagory I spear, on a catagory II hitch on the 1850.
Measure the distance from where the front of the lift arms attach on the 1850, to the top link attaching hole. Should be about 24" for a catagory II. Betting the attaching pins, to top link measurement on the spear will be about 18", which is catagory I.
If this is the case, you just need to extend the top link height on the spear 6 inches, or make a bracket to lower where the top link attaches to the tractor about 6 inches.
/ Oliver 1850 #3
Ditto that.
Only way for the spear to be tipping down when raising is toplink is closer to the lift arms @ the spear than it is at the tractor.
IF they were equal height, the spear would be level throughout the raise.
If the spear was closer at the tractor side, it would tip up when raising.
Do you have more than one place to mount the toplink on the tractor side?? If so, make sure you are using the lowest mounting hole.
If not, you need to modify something like DJ54 said.
Rotary 15,000lb. 4-Post Auto Lift (A64556)
Rotary 15,000lb...
Lot of 2 ForeRunner 12-16.5N.H.S. Skid Steer Wheels and Tires (A64553)
Lot of 2...
2022 CATERPILLAR 272D3 SKID STEER (A65053)
2022 CATERPILLAR...
2021 John Deere 4044M (A64126)
2021 John Deere...
WEATHERHEAD COLL-O-CRIMP T450-1 HOSE CRIMPER (A64276)
WEATHERHEAD...
2025 Electric Cart (A64557)
2025 Electric Cart...
