Ole 55 bearings
/ Ole 55 bearings #1
Windsweptfp
Winchester, Ky
John Deer 2950
We have an old NH 55 hay rake. The horizontal beam bearings have worn out. One has worn through bearing stud & broke off. Are these bearings pressed in? If so, how do you pull out? How do you pull bearing w/ a broke stud?
Any suggestions. Should we scrap, get a new rake?
Any suggestions appreciated.
/ Ole 55 bearings #2
Messicks has a parts catalog on this. Looks like a dust cover then a snap ring and the roller bearing comes out. You may need to weld a bolt on to get it out but a little heat and perseverance will probably do it. They have 12 bearings in stock at $66.
2021 VERMEER LP573XDT VACUUM TRAILER (A63276)
2021 VERMEER...
ATS 40 Gallon 2 Stage Air Compressor (A62679)
ATS 40 Gallon 2...
1999 Nabors Chip Trailer (A62613)
1999 Nabors Chip...
2007 Mercedes-Benz C230 Sedan (A64557)
2007 Mercedes-Benz...
New Quick Attach Power Spreader (A65579)
New Quick Attach...
IH 18' Cultivator (A66408)
IH 18' Cultivator...
