Ole 55 bearings
/ Ole 55 bearings #1
Windsweptfp
Winchester, Ky
John Deer 2950
We have an old NH 55 hay rake. The horizontal beam bearings have worn out. One has worn through bearing stud & broke off. Are these bearings pressed in? If so, how do you pull out? How do you pull bearing w/ a broke stud?
Any suggestions. Should we scrap, get a new rake?
Any suggestions appreciated.
/ Ole 55 bearings #2
Messicks has a parts catalog on this. Looks like a dust cover then a snap ring and the roller bearing comes out. You may need to weld a bolt on to get it out but a little heat and perseverance will probably do it. They have 12 bearings in stock at $66.
Front Tank Bracket (A64126)
Front Tank Bracket...
2019 Mack Granite Tri-Axle Dump w/ Lift Gate 006043 (A62613)
2019 Mack Granite...
2015 Ford Taurus Sedan (A64557)
2015 Ford Taurus...
2024 JOHN DEERE TURF GATOR (A63276)
2024 JOHN DEERE...
2008 PETERBILT 365 (A65643)
2008 PETERBILT 365...
2020 FORD F-350 (A65643)
2020 FORD F-350...
