Oldest Power-Trac
/ Oldest Power-Trac #1
J_J
Super Star Member
JACKSONVILLE, FL
Power-Trac 1445, KUBOTA B-9200HST
Who has the oldest PT, and what is unique about it ?
My PT-1445 has a 45 hp Ford 4 cyc gas engine. I believe it is an early 90's model. It is either unique or antique.
/ Oldest Power-Trac #2
Hay J J send us some pics of that PT. I know I sure would be interested in seeing them as well as many others.
/ Oldest Power-Trac
My Pt looks like any one of the red PT's . The lift arm's are a little different. This may have been one of the experimental machines. I don't know of anyone else with a 45hp Ford gas engine.
/ Oldest Power-Trac #4
Looks to be in good shape. More pics please. When you get time.
/ Oldest Power-Trac
PT-1445 early 90's 45hp Gas , 3 point hook-up.
/ Oldest Power-Trac
16 in rack and forks from a forklift, heavy duty
/ Oldest Power-Trac
left side showing tram pump pto pump gas tank about 12 gal.
/ Oldest Power-Trac
Back side showing radiator. tow adapter.
/ Oldest Power-Trac
Fire extinguisher mounted to back of seat.
/ Oldest Power-Trac #10
Hey, good pics. Thanks. Wow, an actual water cooled gas engine. I wonder what made them switch to the air cooled diesels? The Ford engines seem like they would last an eternity as well.
/ Oldest Power-Trac #11
Thanks for the pics J J. What kind of repair work have you had to do to it over the years.
/ Oldest Power-Trac
I think it is about 10 years old. The folks that had it before me took good care of it. The only trouble I had with it was a starting problem which I finally found. The leads on back of the neutral switch were shorted together. Intermittently I may add. I guess It could have took off if the treadle was not centered.
PT says they don't have much info on this model, or they just don't want people to know. The have to know what engine they put in their machines. /forums/images/graemlins/confused.gif Some one told me it was a Ford industral 4 cyl. Runs great. I have no idea what the model number is.
Can you believe it's 75 degrees here in Jacksonville, Fl ? /forums/images/graemlins/grin.gif
/ Oldest Power-Trac #13
Yeah, it's in the mid-40s here and raining. Very mild winter so far except for a short cold snap a couple weeks ago.
/ Oldest Power-Trac
No big repairs so far. I did rebuild the three cyl up front, and my tilt arm froze to the 2 in pin. I cut it out and welded a new set on. I am in the process of building a backhoe that mounts on the front, and a grapple for the hoe.
/ Oldest Power-Trac #15
That is good service J J. I'll be looking forward to seeing that back hoe.
