older simplicity garden tractor problem
/ older simplicity garden tractor problem #1
automech
SE PA
bx1500
I am posting this question for someone that has been having a hot soak no start on an older simplicity 15 horse Briggs twin. I think the model was a 1548. He states that it runs perfectly but will not restart after a hot shutdown. He must let it cool, then it starts. He wonders if it has something to do with the ignition system because it doesn't seem to have a very hot spark. I have not seen the unit, so I can't add much. He said he replaced the coil assembly and it still didn't help. Any help would be appreciated, since he's been struggling with this problem for a while.
/ older simplicity garden tractor problem #2
That sounds so perfectly like the ignition condenser to me- just the problem it will give. On battery/coil ignition if the points are set right and the spark is yellow, its the condenser which often when bad will not give itself away until the engine is warm. Also check coil to plug wire and spark plug boot.
-Fordlords-
2000 FREIGHTLINER CENTURY CLASS 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2000 FREIGHTLINER...
AUCTION STARTS HERE @ 9AM (A65053)
AUCTION STARTS...
Sitrex 2GL-T Hay Tetter (A65640)
Sitrex 2GL-T Hay...
2022 21ft Scout 210 Dorado Boat with 2011 18ft Magic S/A Boat Trailer (A64557)
2022 21ft Scout...
Landhonor Skid Steer 3Pt Hitch Adapter (A62679)
Landhonor Skid...
John Deere Grill Guard (A65640)
John Deere Grill...
