Older Rexroth Dual gear pump
   / Older Rexroth Dual gear pump #1
hardknocks
metropolis,il
IH 5488
have a old rexroth pump off of a 5488 IH . The gears in good shape and housing just the 2 thrust plates need replaced. Is there any place i can buy these or some body make them?
   / Older Rexroth Dual gear pump #2
When you say thrust plates are you talking the end plates? If so, take to a grinding shop and have them reground or lapped. If it has gaskets on each end, make sure you use the same thicknest.
ther are 2 plates with brass or copper on them. and there is metal missing. i do not know what the correct spec are . and can they add metal to them
   / Older Rexroth Dual gear pump #4
What I was talking about well not work for you. I thought you just needed the end plates where the gears run retrued up. The plates and surface inside you would need some spec and then maybe a surface grinder would work.
   / Older Rexroth Dual gear pump #5
hardknocks,
I believe John henry Foster company in St. Louis is the Rexroth rep for your area. There might be a rebuild kit for your pump available but it could also be that a new pump is les cost that the rebuild.
Since this is from an IH it may also be a proprietary item to IH.
ETS Hydro in Memphis is also a large Rexroth pump rebuild center.
6" & 12" CHANNEL IRON UP TO 23 1/2' LONG (A51247)
6" & 12" CHANNEL...
UNUSED KIVEL 3500# PALLET FORKS (A51248)
UNUSED KIVEL 3500#...
1992 SYLVAN 20' PONTOON BOAT (A51247)
1992 SYLVAN 20'...
THRESHOLD 30" SQUARE OUTDOOR GAS FIRE TABLE (A51248)
THRESHOLD 30"...
2021 JOHN DEERE 6130R LOT IDENTIFIER 45 (A53084)
2021 JOHN DEERE...
