Older Mahindra 485 Transmission Jammed?
   / Older Mahindra 485 Transmission Jammed? #1
gdbaskin
Texas
Mahindra 4110, Mahindra 485, Farmtrac 775, Case 550 E Dozer, Cat 416 Backhoe
I have a Mahindra 485 2WD probably 70's or 80's vintage. The other day out of the blue - the transmission shifter seems to have "become a little loose". In short I cant really get it to shift into any real gear but when I force it a little - the transmission seems to be jammed - and it will kill the engine. If I leave it in neutral - the tractor runs fine in Reverse. Anyone have any ideas?
   / Older Mahindra 485 Transmission Jammed? #2
A little loose ? Detentsprings in softcover broke ! Next step is gears that lock (going in gear that should stay where they are)
   / Older Mahindra 485 Transmission Jammed? #3
Remove gearlever then get all gates in a row and put gearlever back . Locking will happen again.
To repair it those Springs needs replacing
Thanks.
Thank you. I will get right on that.
   / Older Mahindra 485 Transmission Jammed? #6
When removing gearshiftcover take note to Mark all inside before loosening shifterforks...even thoses thin plates !
Could you explain a little more about "Mark all inside before loosening shifter forks".
2014 Ford Taurus Sedan (A56859)
2014 Ford Taurus...
1998 FREIGHTLINER FL50 SPORT CHASSIS (A56129)
1998 FREIGHTLINER...
2022 Harley Davidson Electraglide (A55973)
2022 Harley...
2016 Jeep Compass 4X4 Sport (A56859)
2016 Jeep Compass...
Electric Diesel Fuel Pump with Hose Reel (A55851)
Electric Diesel...
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
