Older Mahindra 485 Transmission Jammed?
   / Older Mahindra 485 Transmission Jammed? #1
gdbaskin
Texas
Mahindra 4110, Mahindra 485, Farmtrac 775, Case 550 E Dozer, Cat 416 Backhoe
I have a Mahindra 485 2WD probably 70's or 80's vintage. The other day out of the blue - the transmission shifter seems to have "become a little loose". In short I cant really get it to shift into any real gear but when I force it a little - the transmission seems to be jammed - and it will kill the engine. If I leave it in neutral - the tractor runs fine in Reverse. Anyone have any ideas?
   / Older Mahindra 485 Transmission Jammed? #2
A little loose ? Detentsprings in softcover broke ! Next step is gears that lock (going in gear that should stay where they are)
   / Older Mahindra 485 Transmission Jammed? #3
Remove gearlever then get all gates in a row and put gearlever back . Locking will happen again.
To repair it those Springs needs replacing
Thanks.
Thank you. I will get right on that.
   / Older Mahindra 485 Transmission Jammed? #6
When removing gearshiftcover take note to Mark all inside before loosening shifterforks...even thoses thin plates !
Could you explain a little more about "Mark all inside before loosening shifter forks".
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A56436)
Adams Load Out...
2018 TowMaster T-12D T/A Flatbed Trailer (A55853)
2018 TowMaster...
2011 BMW 750Li Sedan (A55973)
2011 BMW 750Li...
2015 Ford Fusion Hybrid Sedan (A56859)
2015 Ford Fusion...
Globel Industrial 44" Water Cooled Fan, 24" Electric Pedestal Fan (A59076)
Globel Industrial...
Steel Storage Cabinet w/Contents, 67" W x 24" D x 96" H (A59076)
Steel Storage...
