Older Mahindra 485 Transmission Jammed?
   / Older Mahindra 485 Transmission Jammed? #1
gdbaskin
Texas
Mahindra 4110, Mahindra 485, Farmtrac 775, Case 550 E Dozer, Cat 416 Backhoe
I have a Mahindra 485 2WD probably 70's or 80's vintage. The other day out of the blue - the transmission shifter seems to have "become a little loose". In short I cant really get it to shift into any real gear but when I force it a little - the transmission seems to be jammed - and it will kill the engine. If I leave it in neutral - the tractor runs fine in Reverse. Anyone have any ideas?
   / Older Mahindra 485 Transmission Jammed? #2
A little loose ? Detentsprings in softcover broke ! Next step is gears that lock (going in gear that should stay where they are)
   / Older Mahindra 485 Transmission Jammed? #3
Remove gearlever then get all gates in a row and put gearlever back . Locking will happen again.
To repair it those Springs needs replacing
Thanks.
Thank you. I will get right on that.
   / Older Mahindra 485 Transmission Jammed? #6
When removing gearshiftcover take note to Mark all inside before loosening shifterforks...even thoses thin plates !
Could you explain a little more about "Mark all inside before loosening shifter forks".
2001 International 4700 Bucket Truck, VIN # 1HTSCABNX1H380565 (A51573)
2001 International...
2020 John Deere S790 Combine (A53342)
2020 John Deere...
2011 IHI IC-75 Weld Deck Crawler Carrier (A52384)
2011 IHI IC-75...
Woods 9204RD-2 Flexwing Finish Mower (A51573)
Woods 9204RD-2...
JOHN DEERE 1725 CCS (A53084)
JOHN DEERE 1725...
Adams 5 T Spreader (A53472)
Adams 5 T Spreader...
