Backhoe Older Kelley Backhoe
/ Older Kelley Backhoe #1
Inspector507
Super Member
Central Ohio
I'm going to look at Kelley Backhoe that has been stored 10+ years. The owner said it fits a Cat 0 or a Cat 1 tractor. It only has a 3"sq boom. No hydraulic tank or pump, just fed from the tractor hydraulics. I would assume it would be a B15 model. Anyone know what I'm going to look at?
/ Older Kelley Backhoe #2
I don't know anything about the model you're asking about, but I have had a Kelley model 55 3 pt hoe for about 15 years. It was made in the mid 70's, I believe, and has about a 14' reach. I have used it to clear about 15-20 acres of brush. No problems with it mechanically at all, other than a couple of broken pins and the usual hose rupture. I run it from the tractor hydraulics as well, but it's on a 3414 IH industrial loader tractor with about 20 GPM flow, which is way more than it needs.( Things happen very fast with that flow). Very well built machine, in my opinion. I would buy a smaller one for my 2740 Montana also, if I could find one...Dan.
2022 Deere 317G (A64126)
2022 Deere 317G...
New/Unused Landhonor Hydraulic Quick Attach Pallet Forks (A65583)
New/Unused...
KOMATSU PC490LC-10 EXCAVATOR (A60429)
KOMATSU PC490LC-10...
2024 Kubota RTVXG850GLAS24-A Sidekick Utility Vehicle - 19 hours
2024 Kubota...
2021 DITCH WITCH HX30G VACUUM TRAILER (A63276)
2021 DITCH WITCH...
New 4400lb All Steel Adjustable Gantry Crane (A62679)
New 4400lb All...
