Older John Deere couplers leak, replace?
   / Older John Deere couplers leak, replace? #1
afmyrin
john deere 4450
I have a John Deere 4450 and a 3155. Both have the original hydraulic couplers on the back with the lever you move left or right to hook/unhook the hoses. I have had trouble with these leaking for years. About once a year I replace the seals and o-rings in them but I still spend a fortune on hydraulic oil that ends up on the ground. Does anyone know of a retro-fit coupler that is better? Any other suggestions? Thanks very much.
   / Older John Deere couplers leak, replace? #2
You may need to replace the whole breakaway coupler. JD part number is RE18834 and they are about $100 apiece. If you go that route i would also replace my hose couplers too.
   / Older John Deere couplers leak, replace? #3
get them rebuilt ,john deere couplers are as good or better than any others.since you are having trouble with 2 tractors,your tips may not be the standard ones.get some john deere tips and try it.
John Deere 644G Wheel Loader (A47477)
John Deere 644G...
2015 Freightliner M2 106 Terex BT2047 10-Ton Crane Truck (A51691)
2015 Freightliner...
PALLET OF CHAINS AND BINDERS (A53843)
PALLET OF CHAINS...
Ford F250 Pickup Truck (A51694)
Ford F250 Pickup...
