Older John Deere couplers leak, replace?
   / Older John Deere couplers leak, replace? #1
afmyrin
john deere 4450
I have a John Deere 4450 and a 3155. Both have the original hydraulic couplers on the back with the lever you move left or right to hook/unhook the hoses. I have had trouble with these leaking for years. About once a year I replace the seals and o-rings in them but I still spend a fortune on hydraulic oil that ends up on the ground. Does anyone know of a retro-fit coupler that is better? Any other suggestions? Thanks very much.
   / Older John Deere couplers leak, replace? #2
You may need to replace the whole breakaway coupler. JD part number is RE18834 and they are about $100 apiece. If you go that route i would also replace my hose couplers too.
   / Older John Deere couplers leak, replace? #3
get them rebuilt ,john deere couplers are as good or better than any others.since you are having trouble with 2 tractors,your tips may not be the standard ones.get some john deere tips and try it.
2016 Ford F-250 Ext. Cab Pickup Truck (A53422)
2016 Ford F-250...
2016 KOMATSU PC360LC-11 EXCAVATOR (A53843)
2016 KOMATSU...
5TH WHEEL HITCH (A53843)
5TH WHEEL HITCH...
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A53473)
NEW 2025 Load...
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2016 Peterbilt 320...
2016 Ford Fusion Sedan (A53424)
2016 Ford Fusion...
