The machine randomly just stops like someone turned the key off. Sometimes it restarts ok, but other times it just cranks and cranks. I have removed and tested the fuel shutoff selenoid. It seems ok when I use a jumper to it from the battery. I suspect it is a wiring problem, but the wires disappear into a big sheathed cable, so I don't know how to find the culprit.
My question is it ok to bypass the wiring system and run a switched line directly from the solenoid to the battery or the key?
Changing parts to find the problem is prohibitive. That little solenoid costs over $600.00!
