older (70s?) JD 500c stalling after replacing fuel filter HELP!
   / older (70s?) JD 500c stalling after replacing fuel filter HELP! #1
bigjohn82
virginia
john deere 500c
I decided to change the fuel filter on my backhoe just because I haven't done it since I purchased it from the previous owner, after replacing it the tractor starts up but then dies out after 10 or 15 seconds but then it will fire right back up and then stall again. I went ahead and replaced the mechanical fuel pump just to make sure it wasn't bad and it still does the same thing. Could air in the system cause this?
   / older (70s?) JD 500c stalling after replacing fuel filter HELP! #2
:welcome: to TBN
Sounds like air.
   / older (70s?) JD 500c stalling after replacing fuel filter HELP! #3
Do you have good fuel flow at fitting(parts key 24) with line nut loosened when handle on lift pump is activated? If so check fitting(parts key 23) that contains a check valve for plugging. This check valve has a long history of plugging giving the same symptoms as you describe.
Jim I am away from the tractor until Saturday but I drained the fuel tank before i left it to make sure it wasn't full of trash and found a bunch of black goo in the bottom so I am going to clean that out then do what you said, do I loosen number 24 in the diagram and pump the manual lever? And if I have good flow there what do I do about the check valve in number 23? Replace it? Or is there a way to clean it? Thanks a lot for the info!
2007 IC Corporation PB105 School Bus (A54814)
2007 IC...
20in Digging Tooth Bucket Excavator Attachment (A55973)
20in Digging Tooth...
2005 International 5900i T/A Flammable Liquid Transport Truck (A55973)
2005 International...
skeleton / rock bucket (A56857)
skeleton / rock...
48in Boom Lift Basket (A56857)
48in Boom Lift...
2019 PETERBILT 579 DAYCAB (A58214)
2019 PETERBILT 579...
