Old Plow broke
   / Old Plow broke #11
What size tractor are you planning on using with the plow?
   / Old Plow broke #13
That looks like a total piece of cake to repair.
Remove the U-bolts and the shaft.
Cut everything away from the broken end except for the shaft.
Buy a piece of 2 x 3/4" cold roll.
Cut to length, drill the hole for the pin, then weld it on.
Eassy peezy.
   / Old Plow broke #14
On second thought, there is no need to remove the shaft.
Just set the plow in your shop and repair it right in place.
   / Old Plow broke #15
If yo can weld (or get it to a welding shop) it looks to be an easy fix. I think you will have to cut off the flat pieces that broke, fab up a new piece from a piece of 1/2" plate, drill a hole for a new bolt on pin and weld the plate back to the pipe cross member. Shouldn't take more than an hour at a shop to fix.
   / Old Plow broke
Thanks, I'll start looking for a welding shop or mobile welder.
2014 PETERSON 4700B HORIZONTAL GRINDER (A51242)
2014 PETERSON...
Rollback (A49461)
Rollback (A49461)
2014 International DuraStar 4300 Terex BT3063 30,000LB Crane Truck (A48081)
2014 International...
2006 FAE Mulcher (A49461)
2006 FAE Mulcher...
2007 JOHN DEERE 310SJ BACKHOE (A50458)
2007 JOHN DEERE...
2025 78in Dual Cylinder Hydraulic Grapple Rake Skid Steer Attachment (A50322)
2025 78in Dual...
