Posthole Digger old john deere post hole digger
   / old john deere post hole digger #1
musselmark
grand tracadie PE
'05 NH TN75DA
I bought a used john deere post hole digger and it came with a PTO shaft with a large spring wrapped around the end that goes onto the tractor. Also it has a shear bolt assembly with 4 holes, in one side the holes are almost 3/4" and the other side approx 3/8", what is the idea with this, the head of a 3/8" bolt will go through the larger hole, I attached a picture. I was thinking of drill 2 holes opposite each other for shear bolts. How do I determine the size, should I start with 1/4" or 5/16". The flanges of the shear assembly are pretty sloppy so that is why I think I need 2 bolts. The universal joint has no needle bearings and looks as though it would be impossible to ever remove, can they be changed
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
KOBELCO SK210LC EXCAVATOR (A55745)
KOBELCO SK210LC...
2022 Ford F-150 Pickup Truck (A55852)
2022 Ford F-150...
Honda EU3000is Gasoline Companion Inverter Generators (A51691)
Honda EU3000is...
2012 Dodge Ram 1500 Tradesman Crew Cab Pickup Truck (A53422)
2012 Dodge Ram...
2020 INTERNATIONAL MV607 REEFER BOX TRUCK (A55745)
2020 INTERNATIONAL...
