Posthole Digger old john deere post hole digger
/ old john deere post hole digger #1
musselmark
grand tracadie PE
'05 NH TN75DA
I bought a used john deere post hole digger and it came with a PTO shaft with a large spring wrapped around the end that goes onto the tractor. Also it has a shear bolt assembly with 4 holes, in one side the holes are almost 3/4" and the other side approx 3/8", what is the idea with this, the head of a 3/8" bolt will go through the larger hole, I attached a picture. I was thinking of drill 2 holes opposite each other for shear bolts. How do I determine the size, should I start with 1/4" or 5/16". The flanges of the shear assembly are pretty sloppy so that is why I think I need 2 bolts. The universal joint has no needle bearings and looks as though it would be impossible to ever remove, can they be changed
2022 CHEVROLET TAHOE (A66091)
2022 CHEVROLET...
1998 INTERNATIONAL 2674 6X4 T/A VACUUM TRUCK (A66091)
1998 INTERNATIONAL...
2013 WINSTON AP22024AL-DC T/A 24FT TRAILER (A66091)
2013 WINSTON...
2017 Ford F-250 4x4 Crew Cab Pickup Truck (A68183)
2017 Ford F-250...
2018 Toro Workman Workamn HDX-D Diesel Utility Cart (A66734)
2018 Toro Workman...
2024 CATERPILLAR 255 SKID STEER (A65056)
2024 CATERPILLAR...
