Old Fuel in Diesel Tractor
   / Old Fuel in Diesel Tractor #11
I think one of the hex screws on top of the filter is to bleed fuel to that point. Are you getting fuel there?
I went to the property for another reason and I was a bit rushed. Just wanted to run the tractor engine while I was doing other things. I agree, it does look like a bleeder and one of the first things I will do when I make it back up there. I also have a full maintenance manual that I can't get my hands on at the moment.
   / Old Fuel in Diesel Tractor #13
There's sometimes a small amount of water in some diesels. After sitting for a long time the water will settle to the bottom, then when you try and start, this water will be drawn in first. I would go for a full drain down, fill with new diesel and flush through the pumps and injectors before trying to start. Me, I would put the old diesel through a filter and water seperator funnel, then use it after I've run the motor a while.
   / Old Fuel in Diesel Tractor #14
How cold is it there? Cold does several bad things to diesels.
1. The fuel gells
2. Any water, freezes blocking lines and filters.
That the engine ran for a short time says, injection pump to injectors was okay. Initial focus should be insuring clean fuel to the injection pump.
I'll start at the tank and see how it goes, depending on what kind of yuck I find. If I get to the pump and injectors maybe the manual will fill me in on how to do that. In the "bad diesel" thread a few mentioned the Mr. Funnel. Do you have any experience with that?
1. The fuel gells
I was there during a warm spell in the low 70's. Over the years generally 30's 20's but sometimes down in the teens.
   / Old Fuel in Diesel Tractor #17
You don't need a special funnel.
General diesel troubleshooting steps are what should be done now. Anything else is a waste of time and money.
Get a new fuel filter if you haven't. Drain the tank at the lowest point, probably going into the filter. With the hose off, pour some fresh diesel into tank and flush any crud out until you have clean fuel. Then replace filter and try priming.
You may need to crack each injector feed line to get the air out. Google how to do that. Only back off the nut a 1/4 turn or so. The idea is to get all trapped air out of the lines and through the injection pump up to the injectors. There will be bubbly diesel and then solid stream. It might help to have a second person to bump the starter for this, depending on layout.
   / Old Fuel in Diesel Tractor #18
Im not sure what `Mr Funnel` is on your State side of the pond. What I have is a large plastic funnel with a very fine guage filter in the bottom. My filter will let diesel or petrol [gas] through, but is that fine it will not let crud or water through. Most agriculture/tractor `shops` sell them here, they are not very expensive. I always use mine when I fill up. Again,what I would do in your situation, is drain your system completely, new diesel filter. new fresh diesel, a gallon or two, through my funnel, then when the tractor started, let it run a bit, then filter the old diesel I had took out. and stick it back in.
I heard about it a few days ago from another thread. It sounds similar to yours, blocking debris and water. So do you think diesel is OK no matter how old it is if contaminates are removed? I'm stressed out about a Caterpillar that is stored outside with a 70 gallon tank. I have always kept the tank full but I don't have the equipment to dispose of that much fuel except in portions.
   / Old Fuel in Diesel Tractor #20
Provided the diesel that gets to the engine is clear of water and free of any crud, I don't think it matters how old it is. I was brought upon my dads small farm, and it was cheaper for him to have delivered a big tank full at a time. Sometimes that diesel was years old before it see the tractors, and if the price dropped, dad would order more because it was cheap and stick it on top of the old stuff. I had a small fishing boat, and sometimes the diesel had been in drums 8 - 10 years before it was used, Saying that my boat did have a water filter before the fuel filter. But, whenever I used to top up, I used to always put it through my `filter funnel`, and carefully left any crud and water in the bottom of the drums. The older diesel engines will almost run on any type of oil. You can see on Youtube how to make it out of old `fries` and cooking oil. Modern common rail engines are a bit more delicate, but in your case I definately would not be throwing your old diesel away. On my boat I used to add Stihl 2 stroke oil to the diesel. I thought the engine run a bit `oilier` and better, but never had any proof.
Mini Excavator Quick Coupler (A55272)
Mini Excavator...
2007 BIG TEX TRASH TRAILER (A58216)
2007 BIG TEX TRASH...
KATO Light Diesel Generator (A55272)
KATO Light Diesel...
500 BBL FRAC TANK (A58216)
500 BBL FRAC TANK...
TANK MANIFOLD (A58216)
2007 JLG E400AJP TELESCOPIC/SCISSORING MANLIFT (A52709)
2007 JLG E400AJP...
