Old Ford rake help
/ Old Ford rake help #1
prichard
N. Georgia
B2601 FEL
I've got this old rake I picked up at auction years ago. It has several tines that are bent or broken. I can't figure out how to replace. It seems they have no bolts through them, they just get squeezed between 2 plates.
The problem is there is no way to get to the nuts for the bolts in the middle.
The nuts are under the hat channel that runs down the spine. You can see where I removed the ones on the end but the nuts further in just spin and there's no way to reach them with a wrench.
Ideas?
/ Old Ford rake help #2
Deep well socket.
Deep well socket.
No, got the ones under those holes. There are at least a dozen further it where there are no holes in that top piece.
That was made by Woods so they may be of some help.
Thanks, I didn't realize that.
I found a parts diagram at messnick. It labeled it as ford/new Holland.
But I think from that diagram the top plate, right above the tines might come off if I remove all the accessible nuts on the ends. I'll try that tomorrow.
/ Old Ford rake help #6
Woods made them for Ford. The WD in the serial number is the give away.
/ Old Ford rake help #7
Did you try turning one? Might get lucky and the nuts are welded on top under that C-channel?
2021 Jayco Jay Flight 32BHS Camper (A62613)
2021 Jayco Jay...
1999 New Holland 688 Round Baler (A63688)
1999 New Holland...
2009 International DuraStar 4400 Fuel Tanker (A62613)
2009 International...
(INOP) 2002 CHEVROLET 3500 BUS (A59823)
(INOP) 2002...
SKID STEER AUGER ATTACHMENT (A62613)
SKID STEER AUGER...
New 4400lb All Steel Adjustable Gantry Crane (A62679)
New 4400lb All...
