Old Ford rake help
/ Old Ford rake help #1
prichard
N. Georgia
B2601 FEL
I've got this old rake I picked up at auction years ago. It has several tines that are bent or broken. I can't figure out how to replace. It seems they have no bolts through them, they just get squeezed between 2 plates.
The problem is there is no way to get to the nuts for the bolts in the middle.
The nuts are under the hat channel that runs down the spine. You can see where I removed the ones on the end but the nuts further in just spin and there's no way to reach them with a wrench.
Ideas?
/ Old Ford rake help #2
Deep well socket.
Deep well socket.
No, got the ones under those holes. There are at least a dozen further it where there are no holes in that top piece.
That was made by Woods so they may be of some help.
Thanks, I didn't realize that.
I found a parts diagram at messnick. It labeled it as ford/new Holland.
But I think from that diagram the top plate, right above the tines might come off if I remove all the accessible nuts on the ends. I'll try that tomorrow.
/ Old Ford rake help #6
Woods made them for Ford. The WD in the serial number is the give away.
/ Old Ford rake help #7
Did you try turning one? Might get lucky and the nuts are welded on top under that C-channel?
(1) 380/85R30 TIRE W/8 LUG RIM (A62130)
(1) 380/85R30 TIRE...
2018 CATERPILLAR D6T XL HIGH TRACK CRAWLER DOZER (A62129)
2018 CATERPILLAR...
2009 MULTIQUIP 25KW GENERATOR (A58214)
2009 MULTIQUIP...
2022 John Deere Z930M (A57148)
2022 John Deere...
84in. Fork Extensions (A61567)
84in. Fork...
2010 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A61568)
2010 Dodge Ram...
